Choose your country or region
Heat Pump and Solar Panels: How They Work Together to Reduce Energy Costs
Installing a heat pump can help UK households move away from gas heating, but electricity costs are still worth considering, especially during the colder months. If you already have solar panels, or are thinking about installing them, you may be able to use some of that electricity to run your heating and hot water. Of course, British winters bring shorter days and less sunshine, so solar won’t cover everything. This guide explains how solar panels and heat pumps work together, how much you could save, and what you can do to make the most of both systems.
Key Takeaways
  • Self-powered heating: Rooftop solar panels generate daytime electricity that can power your heat pump, reducing reliance on grid electricity.
  • Bigger bill savings: A suitably sized solar PV system with battery storage can reduce grid electricity purchases for heating and household appliances. Eligible households may also earn payments through the Smart Export Guarantee (SEG).
  • Balancing the seasons: UK solar generation falls between November and February. Smart scheduling and battery storage help maximise solar self-consumption, while grid electricity remains necessary during periods of low generation.
  • Insulation first: Chunky loft insulation, double glazing and properly sized radiators let your heat pump run at low flow temperatures, so every kilowatt-hour of solar power counts.
How Do Solar Panels and Heat Pumps Work Together?
Solar panels generate electricity during the day, which your heat pump can use for heating and hot water. This reduces the amount of power you need from the grid. Here’s how the two systems work together.
Generating Electricity From Solar Panels
Photovoltaic (PV) panels mounted on your roof capture daylight—not just direct sunshine, which is good news for overcast British afternoons—and convert it into direct current (DC) electricity. An inverter then transforms that DC electricity into alternating current (AC) power ready for your consumer unit. Whenever your kettle, washing machine, or heating system switches on, the house automatically draws from this free solar supply before pulling a single watt from the national grid.
How Air Source Heat Pumps Convert Electricity Into Heat
Unlike a gas boiler that burns fossil fuel to create heat, an air source heat pump (ASHP) acts like a fridge in reverse. Using a small amount of electricity to power a compressor and fan, the outdoor unit absorbs latent warmth from the outside air—even when temperatures drop below freezing—and upgrades it to heat water for your radiators, underfloor heating, and hot water cylinder. Because it moves heat rather than generating it from scratch, a well-installed heat pump delivers around 3 to 4 units of heat energy for every 1 unit of electricity it consumes.
Using Solar Electricity to Power a Heat Pump
When your solar panels and heat pump are connected to your home’s electrical system, the heat pump can use available solar electricity to meet part of its heating and hot water demand. The amount of solar power used depends on panel output, household electricity consumption and the heat pump’s operating schedule. Running the heat pump during periods of stronger solar generation can increase self-consumption and reduce reliance on grid electricity.
Supplementing Solar Power With Grid Electricity
After dark on winter evenings, solar panels stop generating and the heat pump draws power from the grid or a charged home battery. Whenever heating demand exceeds what your panels or home battery can supply, your system seamlessly tops up the difference from the grid without any interruption to your warmth. Many British households pair their setup with time-of-use tariffs—Cosy Octopus or Octopus Flux—to buy cheap off-peak electricity overnight when solar generation is offline. With solar battery storage, you can carry surplus daytime generation into the evening and reduce the amount you need to import.
EcoFlow OCEAN 2 Plus single phase home battery
How Much Can You Save by Combining Solar Panels and a Heat Pump?
Savings depend on your home’s heating demand, solar generation and electricity tariff. To get a clearer idea, let’s compare the running costs of a heat pump with and without solar panels.
Comparing Heat Pump Running Costs With and Without Solar Panels
The cost of running a heat pump depends on its seasonal efficiency, household energy demand and electricity tariff. A 2026 UK government study modelled how solar panels and battery storage affect electricity bills in an 84 m² semi-detached home with a heat pump. The results show how combining these technologies can reduce annual household electricity costs.
Heating SetupEstimated Annual Household Electricity CostKey Advantage
Air Source Heat Pump Only£1,622Zero direct fossil fuel use; simple single-system install
Heat Pump + 3.5 kWp Solar PV£931Free daytime hot water and shoulder-season heating
Heat Pump + 3.5 kWp Solar PV + 7 kWh Battery£737Shifts daytime solar surplus and cheap off-peak power into evening peaks
Heat Pump + Solar PV + Battery + Cosy Octopus Tariff£593Combines solar self-consumption, battery storage and cheaper electricity periods
Source: DESNZ, 2026. Modelled results for an 84 m² semi-detached home. These figures represent annual household electricity costs, not heat pump heating costs alone. Actual bills vary depending on household consumption, system performance and electricity tariffs.
Estimating Annual Energy Bill Savings From a Combined System
In the example above, adding solar PV and storage can reduce the electricity bought from the grid for heating. Total savings also depend on how much solar electricity your household uses directly and how much it exports. Under the Smart Export Guarantee (SEG), export rates and terms vary by supplier. To estimate payback, compare a quote for the installed system with expected annual savings using your own consumption and tariffs. For an upfront budget, the guide titled “Install Solar Panels Cost” covers equipment, labour and how system size affects installation quotes.
What Factors Affect the Performance of a Solar and Heat Pump System?
Not every home will get the same results. Roof orientation, heat pump efficiency and insulation all affect how much solar electricity you can use for heating.
Solar Panel Capacity and Roof Orientation
The average solar PV system in the UK is around 4.5 kWp, typically requiring about 12 panels and 20–30 m² of roof space, according to the Energy Saving Trust. However, the right capacity for a home with a heat pump depends on its electricity demand, available roof space and budget. Larger systems may be worth considering where household energy consumption is higher.
An unshaded, south-facing roof with a pitch of around 30° to 40° is generally favourable for annual solar generation. East- and west-facing roofs can still work, although they typically produce around 15% to 20% less electricity annually than south-facing systems. A split east–west array can spread generation across more of the day, with east-facing panels producing more in the morning and west-facing panels later in the afternoon.
Heat Pump Efficiency and Seasonal Performance
Heat pump efficiency is measured by the Seasonal Coefficient of Performance (SCOP), which compares seasonal heat output with electricity consumption. A typical air source heat pump achieves a SCOP of around 3 to 4, according to Nesta.
Lower flow temperatures generally improve efficiency. The MCS Heat Pump Guide recommends considering a maximum design flow temperature of around 45°C for suitable radiator systems. Efficient operation can reduce electricity use and help households make better use of solar power.
Household Heating Demand and Insulation Levels
No amount of solar panels can make up for poor insulation. In older UK homes, topping loft insulation up to 270mm, adding suitable wall insulation and improving double glazing all cut heat loss. With less heating demand, the heat pump draws less electricity, which makes it easier for solar panels to cover part of its consumption. For a baseline, the guide “how many kWh does a house use?” provides household benchmarks to compare with your own meter readings before sizing the system.
EcoFlow PowerInsight 2 Home Energy Monitor
How Can You Reduce Energy Bills With Solar Panels and a Heat Pump in the UK?
Besides choosing the right equipment, how you use electricity throughout the day also matters. A few adjustments to heating schedules and energy storage can help reduce grid consumption and keep bills down. EcoFlow’s home energy ecosystem shows how compatible solar, storage and monitoring equipment can work together.
Scheduling Heat Pump Operation Around Solar Generation
Instead of letting your heating sit idle all afternoon and cranking it up at 6:00 PM when the sun has set, shift your heating curve forward. Programming your heat pump to warm the house by an extra 1°C or 2°C between 11:00 AM and 3:00 PM uses peak midday solar output to bank thermal warmth inside your brick walls and floors, letting the system coast quietly through the expensive early-evening peak.
Storing Surplus Solar Electricity in a Home Battery
UK winter heating demand peaks when daylight hours are shortest, meaning daytime solar surplus does not always line up neatly with when your family needs warmth most. Adding a whole-home solar-plus-storage system bridges that gap by capturing unused afternoon solar power and feeding it back to your consumer unit and your heat pump after dusk. For instance, the EcoFlow OCEAN 2 Plus Single Phase hybrid system features 3 independent MPPT channels, allowing it to manage separate PV strings individually and adapt flexibly to multi-aspect British roofs or partial shading from chimneys and neighbouring trees. Paired with its modular battery storage, your household can hold onto daytime solar generation for evening heating cycles and cut back on peak-rate grid imports.
Using a Hot Water Cylinder to Store Heat
Most UK air-to-water heat pumps require a dedicated hot water cylinder, and that tank doubles as a remarkably cost-effective thermal battery. By scheduling your heat pump’s daily domestic hot water heating and its weekly Legionella sterilisation cycle for midday when solar generation is strongest, you effectively store free solar energy as piping-hot water ready for evening baths and morning showers without spending a penny on grid power.
Monitoring Solar Generation and Household Energy Use
Balancing solar generation, hot water cycles, and space heating works best when you can see exactly where every kilowatt is going in real time rather than guessing from a monthly bill. The EcoFlow PowerInsight 2, equipped with an 11-inch touchscreen display, brings live solar generation, household consumption, and battery activity from compatible systems together in one clear dashboard. Checking those live energy flows makes it straightforward to spot when excess solar power is available, adjust your heat pump schedule accordingly, and build smarter everyday energy habits.
Solar panels can help reduce the electricity costs of running a heat pump, particularly during spring and autumn when there is often enough daylight to support daytime heating. Winter is more challenging, but good insulation, sensible heating schedules and home battery storage can still help you make better use of available energy. If you’re considering both systems, start by checking your home’s heating demand, roof suitability and electricity tariff. An MCS-certified installer can then help you work out the right system size and whether adding battery storage makes financial sense for your household.
How Many Solar Panels Do I Need to Run a Heat Pump?
Most three-bedroom UK homes need around 10 to 14 solar panels (4–6 kWp) to cover a big share of their annual heat pump electricity use. That won’t meet all the heating demand in winter, but it can carry heating and hot water through spring and autumn, with surplus summer electricity earning export payments.
Is It Worth Adding a Battery to Existing Solar Panels?
Yes, a battery can pay off if you run a heat pump, especially when you generate surplus solar during the day. It stores that energy for evening heating and can also charge on cheaper overnight tariffs in winter, so you lean less on expensive peak-rate electricity. How much you save, though, comes down to your tariff, how you use power and what the battery costs.
Are There Any UK Grants or Loans for Installing Solar Panels and Heat Pumps in 2026?
Yes. In England and Wales, the Boiler Upgrade Scheme offers £7,500 towards eligible air-to-water and ground source heat pumps. Until 31 March 2027, eligible off-gas-grid homes replacing oil or LPG heating can receive £9,000 for these systems. Qualifying installations of heat pumps, solar panels and batteries can receive 0% VAT through 31 March 2027. In Scotland, Home Energy Scotland offers eligible households up to £7,500 for a heat pump, rising to £9,000 for homes eligible for the rural and island uplift, with interest-free loans also available. Eligible households in England may qualify for improvements through the Warm Homes: Local Grant.
Do Solar Panels Generate Enough Electricity to Run a Heat Pump in Winter?
No. Solar panels alone generally can’t keep a heat pump running through winter, when daylight is short and heating demand climbs. They still generate on bright winter days, though, which cuts how much you draw from the grid. Summer Smart Export Guarantee (SEG) payments can also help offset winter electricity costs.
Do Solar Panels and Heat Pumps Need Regular Servicing?
Yes. Heat pumps generally need servicing once a year, otherwise efficiency drops off and your warranty may not hold up. Solar panels are far less fussy while inverters and batteries need little more than a check now and then and the occasional software update.
Home Heating System
