Choose your country or region
What Are High-Performance Homes?
Modern homeowners are increasingly looking for new methods to make their homes more energy-efficient and resilient. High-performance homes achieve this by combining energy-saving construction with smart home technologies, efficient HVAC, and renewable energy solutions.
What does a high-performance home mean?
A high performance home is mainly designed to provide greater energy efficiency, comfort, and overall functionality. It utilizes efficient building materials, smart technologies, and modern systems, decreasing energy wastage and operational costs. These homes maintain a comfortable indoor environment and minimize their adverse environmental impact.
Key features of high-performance homes
  • High-performance building envelope
A high-performance house envelope maintains a stable indoor temperature year-round. It generally includes well-insulated walls, floors, and roofs, as well as energy-efficient windows and properly sealed doors. These features reduce heat transfer and air leakage, helping the home use less energy for heating and cooling. A well-designed home envelope also enhances indoor comfort while reducing outdoor noise.
  • Efficient HVAC and ventilation
Efficient heating, ventilation, and air conditioning (HVAC) maintains a comfortable indoor temperature without excessive energy usage. High-performance homes mostly use smart thermostats, energy-efficient heat pumps, and properly sized HVAC equipment. Mechanical ventilation can also enhance the indoor air quality by providing a stable supply of fresh air. Altogether, these systems balance efficiency, comfort, and healthy indoor conditions.
  • Efficient electrical and home systems
High-performance homes utilize efficient electrical systems and appliances to reduce unnecessary energy consumption. Smart controls, LED lighting, ENERGY STAR-rated appliances, and energy-efficient water heating make everyday energy use much more efficient and effective. Smart home technologies also automate appliances, lighting, and other systems based on usage patterns and occupancy. This enables homeowners to reduce energy wastage while maintaining convenience.
  • Solar, battery storage, and energy management
Solar panels can produce clean energy for the home, whereas battery storage stores excess energy for later use or provides backup power during outages. An energy-efficient system helps monitor consumption and optimize the timing of energy production, storage, and use. The EcoFlow OCEAN Pro stands out in this regard as it supports whole-home energy management by storing solar energy and providing a reliable backup source. This combination enhances resilience, energy independence, and overall home efficiency.
Benefits of high-performance home systems
  • Lower energy bills: High performance homes utilize energy more effectively, which reduces unnecessary consumption. This, in turn, lowers monthly electricity and heating or cooling costs.
  • Improved indoor comfort: Efficient insulation, HVAC, and ventilation systems help in keeping more consistent indoor temperatures. They also reduce drafts and hot or cold spots.
  • Greater energy resilience: Battery storage, solar generation, and battery management systems lessen the reliance on traditional power grids. The stored energy provides power even when the solar generation is unavailable, leading to greater energy independence.
  • Better indoor air quality: Modern ventilation systems remove stale air, excess moisture, and pollutants from the home. This results in a fresher and more comfortable indoor environment.
  • Reduced environmental impact: Using less energy and generating energy from renewable sources decreases a home's carbon footprint. Efficient systems also help in conserving resources over the long term.
Are high-performance homes worth it?
Yes, high performance homes are worth considering for homeowners seeking greater efficiency, comfort, and long-term savings. Although some energy-efficient upgrades may require a higher upfront investment, they reduce energy waste and lower ongoing utility costs. Features like improved insulation, smart controls, efficient HVAC systems, and renewable energy enhance daily comfort. Over time, these benefits make a home much more resilient, cost-effective, and sustainable to operate.
For homeowners looking for energy independence, the EcoFlow OCEAN Pro Solar Battery System is the best choice. It supports up to 40kW of solar input, provides 24kW of continuous output, and offers valuable battery storage from 10kWh to 80kWh. The system also works efficiently with solar, grid, and generators, providing flexible whole-home backup.
Through the EcoFlow App, homeowners can easily monitor and optimize energy usage, helping to create a more efficient, smarter, high-performance home. The owners can also optimize how the power is sourced from solar, grid, or backup generators. Its integrated approach helps in creating a more responsive home energy system which can easily adapt to changing electricity conditions and household demands, making it a great practical addition to modern high-performance homes.
25%
I'm not sure / Just exploring
In conclusion, high-performance homes are quickly becoming popular as they combine smart technologies, energy-efficient construction, efficient HVAC systems, and renewable energy solutions, creating a more sustainable and comfortable living ecosystem. From improved air quality and lower energy bills to greater energy independence and resilience, these features deliver long-term value. Thus, investing in high-performance homes allow homeowners to reduce energy waste and enhance overall reliability and comfort.
For a complete home energy solution, the EcoFlow OCEAN Pro Solar Battery System is worth considering. It is the best solution for homeowners seeking an energy-independent, renewable lifestyle. So, if you are looking for the ideal way to enjoy energy independence in your home, then be sure to request a consultation with our professional representatives today!
What is considered a high-performance building?
A high-performance building utilizes fewer resources and energy while keeping a comfortable and healthy indoor environment. Efficient building envelopes, HVAC systems, lighting, ventilation, and smart energy management all contribute to better performance.
How much does it cost to build a high-performance home system in the U.S.?
The cost of a high-performance home system varies significantly depending on the home's location, size, materials, and installed energy systems. Estimates show that the premium for energy efficiency can be a modest $3,300 to $7,800 for a code-compliant home, while more robust, custom high-performance builds can add $25,000 to $50,000 compared to a standard construction project
Can I add solar power to a high-performance home?
Yes, solar power is quite an effective way to improve energy efficiency and independence of a high performance home. Solar panels can generate clean electricity, whereas battery storage keeps excess energy available when solar production is low or during outages. The EcoFlow OCEAN Pro Solar Battery System can pair up with a home solar system to store excess energy, providing reliable backup power.
Home Improvement
