Choose your country or region
2026 Grants for PV Panels and Home Energy Solutions in the UK
Grants for PV panels can lower your upfront costs and speed up your return on investment. If you are planning a PV system installation or looking to reduce the total expense, keeping up to date with the latest UK solar grants heading into 2026 is worth your time.
What Solar Grants Are Available in the UK in 2026
Several solar panel grants are available to UK homeowners in 2026. These cover PV panels, full PV systems, and hybrid setups that bundle solar with battery storage. Aside from providing aid for different packages, they also have grants that are modelled for specific groups.
  • For UK residents, the Warm Homes Local Grant is a scheme that aims to help low-income households get access to energy efficiency upgrades, including solar panels and better home insulation.
  • The ECO4 scheme provides low-income and low-EPC-scoring households in England with funding for energy efficiency improvements. The programme runs until 2026.
  • There are also EU and national funding windows for solar and energy modernisation.
Many programmes prioritise hybrid PV systems that combine solar with storage, as these increase self-consumption. A solar system with storage generates electricity and gives households greater independence from the grid.
Who Qualifies for Solar Panel Grants in the UK
Before applying for any solar grant, check the eligibility requirements for each scheme. Some grants are designed for low-income households, while some consider your EPC (Energy Performance Certificate) score. Some schemes are designed for more efficient homes, while others aim to help households with low EPC scores and improve their efficiency.
Local authority grants also exist for homeowners in varying financial situations. Most schemes give priority to households experiencing energy poverty. These grants help reduce energy costs and raise the home's efficiency rating.
Grants for PV Panels, VAT Relief, and Solar Export Payments
In the UK, grants for PV panels are partnered with VAT relief and export payments. For qualifying systems, there is a 0% VAT relief for UK PV system installations through 2027. This means that qualified homes will not incur any VAT when installing a PV system.
The Smart Export Guarantee (SEG) is a UK scheme that pays households for surplus solar electricity exported to the grid. Homeowners sell their excess energy to their supplier at an agreed rate. However, rates can change yearly, so it is better to check with your suppliers if there are any updates.
Grants for solar battery storage UK
The grants for solar battery storage UK residents can apply for help increase their grid independence and self-consumption. The UK government encourages this to meet the country’s sustainability goals faster.
Home battery storage stores surplus solar energy for use during peak grid hours. Schemes reward solar and storage systems with faster payback on their units, plus long-term savings. This is a welcome alternative as export rates can be low or change at any moment.
You can also optimise home storage solutions like EcoFlow PowerOcean with intelligent management systems. This way, you can maximize your solar yield and energy storage. EcoFlow's Home Energy Management System (HEMS) and PowerInsight 2 help you manage stored energy and apply smarter load shifting strategies.
Solar grants for a four-person family with an energy storage installed outdoors
Can I Get a Grant for Solar Panels? How to Apply and Stay Eligible
The short answer is yes, but only if you meet the specific requirements. Here is a step-by-step guide on how to get a grant for your solar panels.
  1. Do your research by checking the national and local scheme pages. Here you can see the necessary details and benefits of each scheme.
  2. Check the requirements and see if you are eligible.
  3. Combine VAT relief and local loan programmes where available. This way, you can soften the blow of the initial monetary investment needed when purchasing and installing solar panels.
  4. Only work with reputable and MCS-certified installers. Accredited installers handle compliant paperwork and provide higher quality service.
Solar Grant Checklist for UK Homeowners
Always check your grant eligibility when applying. Different grants have their own set of requirements, and it is better to confirm your eligibility and requirements. Here are other tips to take note of:
  1. Review VAT relief rules
  2. Confirm smart meter needs with your supplier and make sure that you have an approved smart meter.
  3. Compare the SEG options available. Getting a competitive rate helps you earn more from exporting your surplus generated energy.
  4. Properly size your home battery to match your household energy demands. With PowerOcean's modular battery system, you can start with one 5 kWh unit and add more as your needs grow.
  5. Request quotes from accredited installers as they will not only help you with paperwork but also provide quality service.
FREE CONSULTATION
Home Energy Storage System (e.g. OCEAEN 2)
I'm not sure / Just exploring
Maximise Your Home's Energy Efficiency with Solar Grants in 2026
Grants for PV panels can help UK households increase their self-consumption and contribute to the country's sustainability goals. Request a consultation with EcoFlow to get expert advice on PV with storage systems.
1. Are there any grants for solar panels in the UK?
Yes. The ECO4 is a programme that funds energy efficiency upgrades for qualifying UK homes. The Warm Homes Local Grant also supports low-income households with solar panel funding.
2. Do I still pay for electricity if I have solar panels in the UK?
In most cases, you will still need to pay for your electricity even if you use solar panels. Unless you are 100% independent from the grid, you will still make use of grid-provided energy every day. Having higher self-consumption can go a long way.
3. What is the downside of solar panels in the UK?
Solar panels and systems will take up a lot of space on your rooftop. Also, some areas in the UK have homes built close to each other, which can be a challenge during installation. Lastly, solar panels are very costly initially.
4. Who is eligible for solar panel grants in the UK?
Different UK schemes have varying eligibility metrics. Most grants prioritise lower-income households. Some schemes are also designed for homes that scored low efficiency scores and aim to fund renovations and improvements.
5. Is it still worth getting solar panels in the UK?
Yes. The UK offers multiple grants, export schemes, and programmes to help fund solar panels. There is also a 0% VAT relief on qualifying solar installations through 2027. As the UK continues to invest in clean energy, solar panels provide growing value for homeowners.
Home Solar System
