One platform, three deployment modes – compatibility conditions summarized for faster system selection
| PRODUCT / COMPONENTEcoFlow OCEAN Pro BESS | SOLAR ONLYGrid required | SOLAR + BATTERYWithout backup | SOLAR + BATTERYWith backup | NOTESConfiguration Conditions |
| ECOFLOW OCEAN SERIESCORE SYSTEM | ||||
| OCEAN Pro 24kW Inverter | Supports up to two inverters operating in parallel in the same system. | |||
| Ocean Pro 10kWh Battery | - | Each inverter supports 0-8 battery units. | ||
| ECOFLOW OCEAN SERIESMETERING INTERCONNECT DEVICE · CHOOSE ONE FOR BACKUP | ||||
| OCEAN Smart Electrical Panel 40 (SEP40) | - | - | Can operate independently. Up to 3 units can be used in the same system. | |
| OCEAN Smart Electrical Panel 8 (SEP8) | - | - | Can operate independently. Up to 3 units can be used in the same system. | |
| OCEAN Gateway | - | - | For backup applications with the ESS system. Up to 3 units per system. | |
| OCEAN MBS | - | - | For backup applications with the ESS system. Not recommended with SEP or Gateway. | |
| ECOFLOW OCEAN SERIESOPTIONAL ACCESSORIES | ||||
| OCEAN EV Charger | Can operate independently, with the inverter, or together with SEP. | |||
| PowerInsight 2 | Recommended for use together with the BESS. | |||
| ECO-PRODUCTSOPTIONA | ||||
| All EcoFlow Portable Power Stations (PPS) | - | plug & play | plug & play |
| Dual-Fuel Portable Generator | - | plug & play | plug & play | |
| THIRD-PARTY PRODUCTSOPTIONAL · ENERGY SOURCES | ||||
| Third-Party Solar System | Backup operation must be used with SEP or Gateway. | |||
| Standby Generator | - | Must be used with SEP or Gateway. | ||
| EVs with V2L | - | plug & play | plug & play | |
| THIRD-PARTY PRODUCTSRAPID SHUTDOWN AND OPTIMIZATION · CHOOSE A COMPATIBLE OPTION | ||||
| APsmart RSD | Default recommendation. | |||
| Tigo RSD | Requires replacement of the RSD transmitter inside the inverter. | |||
| Tigo Optimizer | Must be used together with a CCA. | |||
