Choose your country or region
Texas Flood Warning: A Critical Preparedness Checklist for Home Power and Safety
A man in a dark, dimly lit kitchen, looking up and holding a smartphone above his head, possibly trying to get a signal or light up the room. The kitchen features white cabinets and various kitchen items on the counter.
Floods are becoming more frequent across Texas. When power outages follow heavy rain, many households find themselves unprepared. If you live in a high-risk area or rely on large energy use at home, now is the time to act. This emergency checklist helps you prepare for the worst, and protect your family, home, and power supply.
Why Power Backup Must Be the First Step on Your Emergency Checklist
Every time a storm hits, the grid in parts of Texas goes dark. Even short blackouts can affect your refrigerator, water pump, medical devices, and security systems. For homes with large appliances or home offices, power is essential, especially when lives or safety depend on it.
The first thing on your Emergency Checklist should always be your home energy system. A dependable battery setup allows you to store energy before the storm and use it when the grid is down. That means uninterrupted lighting, appliances, and communications when they matter most. To make this possible, here are three key considerations for your backup energy system:
  1. Store enough power for at least 72 hours
  2. Choose a system that supports solar input and automatic switchover
  3. Prioritize modular expansion so you’re ready for future needs
What Kind of Energy System Works Best in Flood Conditions?
Not every backup system is ready for Texas weather. Flood zones need storage that’s resilient, flexible, and able to run off-grid.
When building your Emergency Checklist, look for these specific traits:
Feature Why It Matters in a Flood
Modular Expansion Prepares you for increased loads as your needs grow
Off-Grid Capability Keeps power running even when grid connections fail
24kW+ Output Power Supports HVAC, pumps, EV chargers, and whole-house demand
Remote Monitoring Lets you stay safe—no need to physically check during floods
For Texas homes with electric HVAC, well water systems, or medical equipment, they’re non-negotiable.
Step 1: Know Your Top Power Priorities First
Texas homes often rely on large appliances to stay safe—like sump pumps, HVAC, or oxygen machines. During a flood-induced outage, power may only last a few hours unless you plan ahead. Choosing what to run and what to pause helps your system last longer. Without a clear plan, even a large battery can drain too quickly.
Here are common essentials to list in your Emergency Checklist:
  • Water pumps and filtration
  • Refrigerators and deep freezers
  • Medical equipment (CPAP, insulin coolers)
  • Emergency lighting and radios
  • Phone chargers and Wi-Fi routers
  • Air conditioning or heating, depending on the season
Once you’ve listed them, calculate their combined watt-hour needs. Go slightly over the estimate, running out mid-storm isn’t an option.
Step 2: Add Core Supplies to Your Emergency Checklist
Backup power is crucial, but it’s only part of the picture. You also need the right physical supplies stored and ready, especially in waterproof containers.
Category Recommended Items
Power & Energy Home battery backup, flashlights, solar panels, spare batteries
Food & Water Bottled water (1 gal/person/day), canned food, manual can opener
Communication NOAA weather radio, spare phone battery, signal whistle
Health & Hygiene First aid kit, sanitation wipes, necessary prescriptions
Check your supplies twice per year. Storm season in Texas can stretch from spring to late fall.
Step 3: Keep Your Energy Storage System Safe During a Flood
Flooding and electricity are a dangerous mix. Even a large, well-designed battery won’t help if it’s damaged or submerged.
Strengthen your setup with these protections:
  • Mount systems at or above flood line; never in a basement
  • Choose sealed, weather-rated gear for outdoor use
  • Never place lithium batteries in basements
  • Add surge protectors for lightning-prone areas
During your initial installation, ask about waterproof ratings and auto-shutoff features. These small details make a big difference during a major event.
A residential roof covered with dark tiles and multiple blue solar panels, with a skylight visible. The image is taken at night, with a clear sky full of stars in the background.
Step 4: Expandable Energy Is Your Long-Term Strategy
Many Texas families find out too late that their systems are too small. Air conditioning, second fridges, and EVs demand more power than expected. Starting with a scalable system saves time and money later.
For example, if your current battery bank covers 10kWh, you may need 30kWh or more once you add:
  • A second refrigerator or freezer
  • Upgrading to electric HVAC
  • Installing EV chargers
  • Running full lighting for multiple rooms
For homes in Texas with large footprints or multi-family use, a scalable energy system is critical.
This is where EcoFlow OCEAN Pro offers a unique advantage. It starts small and expands up to 80kWh, with 24kW continuous output, and supports off-grid operation—perfect for flood-prone areas. Its modular design means expansion is fast and doesn’t require full rewiring.
Step 5: Keep Your Emergency Checklist Up to Date
A one-time checklist won’t cut it. Households change. Flood zones change. Technology changes. Your checklist should reflect all of that.
Set calendar reminders for:
  • April or May before hurricane season
  • September or October ahead of heavy rains
When you update your Emergency Checklist, be sure to:
  • Replace expired food or medications
  • Recharge and test power systems
  • Review home load estimates
  • Update your list of emergency contacts
Treat this list like a living document. The more accurate it is, the more likely you’ll stay safe and powered through a storm.
Smart Power Planning Starts with the Right Emergency Checklist
In Texas, floods are occurring more frequently. So are outages. Your home needs more than bottled water and candles. It needs a clear Emergency Checklist and a reliable power strategy.
For homeowners managing large loads or off-grid risk, backup power should be central to all planning. And among advanced systems, EcoFlow OCEAN Pro delivers the scale, flexibility, and safety features real families need during floods.
Start early. Check twice a year. And make sure your power solution can grow with you. Storms will return—but so will you, fully powered.
Learn MoreGet a Quote
Q1. How do I choose the right energy storage system for my home during a flood?
When selecting an energy storage system for flood-prone areas, consider systems that offer modular expansion. These systems allow you to scale up as your power needs grow. Additionally, look for off-grid capabilities to ensure your system works even when the grid goes down. A key factor is battery capacity, choose a system that supports at least 72 hours of energy for your home. Make sure the system is rated for waterproof or flood-resistant environments to avoid damage during a storm. Finally, ensure your system has automatic switching during outages so you don’t have to worry about manual intervention.
Q2. Can solar power systems work effectively during floods?
Yes, solar power systems can still function during floods if properly designed. Look for solar panel systems that are mounted high enough to avoid floodwaters. Solar inverters, which convert DC to AC power, should be placed in waterproof enclosures. A system with battery storage will allow you to store excess energy when the sun is out, providing power even during cloudy or rainy days. Flood-resistant panels and weatherproof inverters are crucial to ensuring the system remains operational in harsh conditions. Make sure to also check if your solar system is compatible with off-grid capabilities to maintain power during a blackout.
Q3. What is the lifespan of an energy storage system in flood-prone areas?
The lifespan of an energy storage system depends on several factors, including the battery type and environmental conditions. In flood-prone areas, systems with lithium iron phosphate (LFP) batteries generally have longer life spans, lasting up to 10–15 years with proper maintenance. However, exposure to extreme weather and flooding can reduce system longevity, so it’s important to install your system in elevated, dry areas. Regular maintenance checks are recommended to ensure that the system operates efficiently over time. Additionally, selecting a system with modular expansion can help prolong its lifespan by allowing you to add more capacity as your needs increase.
Q4. How often should I perform maintenance on my energy storage system?
Regular maintenance is essential to ensuring that your energy storage system performs well, especially in flood-prone areas. It is recommended to check the battery health and connections every 6–12 months. After significant weather events, such as floods or storms, inspect the system for water damage or signs of wear. Ensure that filters and vents (if applicable) are clean to prevent overheating. Additionally, inspect inverter systems for any signs of malfunction or performance dips. If your system is outdoor-rated, check for seal integrity and water resistance after each storm season. Regular checks will maximize the system’s efficiency and longevity.
Q5. Can I use my energy storage system to power an electric vehicle during a flood emergency?
Yes, you can use your energy storage system to charge an electric vehicle (EV) during a flood emergency, but certain conditions need to be met. Your system must have a high enough discharge rate (typically 7–11kW for Level 2 home chargers). Additionally, you need a separate load controller to manage the energy flow between the house and EV. It’s important to confirm that your energy storage system can handle this high-load demand without draining too quickly. Modular systems that allow for increased battery storage are beneficial, as they offer the flexibility to charge your EV while maintaining power to other essential devices.
Home Battery Backup
