Choose your country or region
How Long Can Solar Battery Power a House During an Outage?
Imagine you're cooking dinner, lights are on, the kids are watching TV—and suddenly, everything goes dark. No warning. No time to react. This is not just a small inconvenience. It's a reminder that homes depend on constant power. That’s why solar power batteries for whole homes are now a serious option, especially for large houses. But how long can they actually last?
On Solar Power Batteries for Homes
Solar power batteries for homes store the energy collected from rooftop solar panels. During the day, solar panels gather electricity. That electricity can be used right away or saved in the battery for later. When the power goes out, the stored energy becomes your backup source.
Let’s look at EcoFlow OCEAN Pro as an example. This system stores up to 80 kWh when fully expanded. It supports 24kW continuous output, which means it can run many home appliances at once. It also handles tough environments like floods or heat up to 140°F.
OCEAN Pro is designed for people who want to keep their whole house running, not just one or two rooms.
Take a look at the EcoFlow OCEAN Pro Battery's key strengths as a whole-house backup
Feature Category
What It Offers
Storage Capacity
Expandable from 10kWh up to 80kWh for large home power needs
Power Output
Supports 24kW continuous and 50kW peak output with 205A startup current
Solar Input
Accepts up to 40kW solar input with 8 MPPT channels
Whole-Home Readiness
Runs HVAC, kitchen, laundry, and more simultaneously
Flood Resistance
Handles flood depths up to 3.3 feet
Heat Protection
Operates in temperatures up to 140°F
Fire Safety
Built-in fire suppression module and explosion-proof valve
Design Options
Chassis in aluminum, walnut wood, or carbon fiber with NFC lighting
Smart Integration
AI-powered assistant and energy dashboard; integrates with smart home systems
Durability
Rated IP67 for water and dust protection
Industry-leading 15-year warranty
Modularity
Start small and scale later with stackable battery units
When to Consider Solar Power Batteries for Homes Rather Than Traditional Generators
Whole-house power needs are much bigger than just lights and phone chargers. You need backup for large appliances, air conditioning, kitchen equipment, heating systems, and more. In this case, traditional gas or diesel generators are often used. But they also bring many problems:
  • They burn fuel, which must be stored safely
  • They make a loud noise and release harmful smoke
  • They need repairs, oil changes, and care over time
  • They may stop working in bad weather or after long storage
For people with large homes, these problems become even harder. More fuel is needed. More noise is created. Maintenance takes more time.
Solar power batteries can be a better fit for whole-house needs. Here is why:
  • They charge during the day using solar panels
  • They work quietly and do not create air pollution
  • They do not need gasoline or diesel
  • They are safe to use often, even when the grid is not down
Some systems, like EcoFlow OCEAN Pro, are made to handle large homes. They can run ovens, laundry machines, refrigerators, and heating or cooling systems. With enough battery storage, you can keep your full home running for hours or even days.
In addition, OCEAN Pro connects multiple energy and backup sources—including solar, grid power, batteries, portable generators, and EcoFlow power stations—to create a more robust and comprehensive whole-home backup energy system.
Let’s take a common base size, a 10kWh solar battery as a simple example.
By Appliances
The table below shows how long a 10kWh battery might power certain household items:
Appliance
Power Used (Watts)
Estimated Time (10kWh)
Refrigerator
150W
About 66 hours
Wi-Fi Router + Modem
20W
About 500 hours
LED Lights (10 bulbs)
100W
About 100 hours
Window AC Unit
1000W
About 10 hours
Microwave
1200W
About 8 hours (in use)
Electric Oven (active use)
2000W
About 5 hours (in use)
Washing Machine
500W
About 20 hours
TV (55 inch LED)
100W
About 100 hours
Keep in mind: Most people don’t use all devices at once. You can choose what to run, and for how long. That helps your battery last longer.
By House Size
Larger homes use more power. Here’s a basic idea of how long 10kWh might last:
House Size
Daily Power Use (kWh)
Hours of Backup with 10kWh
Small Apartment
5–8 kWh
24–36 hours
2-Bedroom Home
12–15 kWh
12–18 hours
3–4 Bedroom House
20–25 kWh
6–10 hours
Large House (5+)
30–40 kWh
3–6 hours
For full-day backup, large homes often use multiple battery units, like stacking eight 10kWh EcoFlow OCEAN Pro batteries for up to 80kWh.
Learn MoreGet a Quote
How to Size Solar Power Batteries for Your Whole House
First, check your power bills. Look for your average daily energy use in kWh. This tells you how much energy your home needs.
Then ask: Do you want backup for all devices or only the important ones? If you only need lights, internet, and the fridge, a 10 kWh system may be enough. If you want to power HVAC, ovens, and washers too, you will need more.
Here is a simple method:
  • List your must-run devices.
  • Add their energy needs in kWh.
  • Multiply that by how many hours you want to stay powered.
For full-home backup, many people need 20 kWh to 40 kWh. Some may even go up to 80 kWh. The EcoFlow OCEAN Pro battery system can scale up, so you can start with one battery and add more later.
Also, think about solar panel size. You may want to recharge during the day. If you have enough panels, the battery can refill between outages or overnight use.
Solar Battery Backup: Key Insights
Power outages are not rare anymore. From storms to wildfires to overloaded grids, homes face more risks every year.
Solar power batteries for homes give you more than power. They offer quiet, clean, and reliable energy. With large systems like the EcoFlow OCEAN Pro, even big homes can stay fully powered during long blackouts.
Here’s what you should remember:
  • A 10 kWh battery can run small homes for a day or large homes for a few hours
  • Bigger homes may need 40 kWh or more to stay online for 1–2 days
  • EcoFlow OCEAN Pro offers scalable storage up to 80 kWh
  • Solar batteries are cleaner and quieter than fuel generators
  • Daily use plus blackout protection adds long-term value
Check your power use, set your backup goals, and choose the system size that fits your life. Peace of mind begins with smart energy planning.
Sleek modern kitchen with integrated solar batteries ensuring essential appliances function during power outages.
FAQs about Solar Battery
Q1. How many kWh do I need to power my whole house?
A: It depends on how much energy your home uses in one day.
  • A small home may need 10–15 kWh.
  • A medium-sized house may need 20–30 kWh.
  • A large house with AC, laundry, and electric cooking may need 40–80kWh.
Check your monthly power bill to find your average daily use. That number helps you choose the right battery size.
Q2. What happens if my battery runs out during an outage?
A: If your battery is empty and there’s no sun, power will stop. To avoid this, you can:
  • Add more battery storage
  • Use a gas generator as backup
  • Reduce power use during blackouts
Some systems also let you check how much battery is left from your phone. That helps you plan better during emergencies.
Q3. Can I start small and expand later?
A: Yes. Many large systems are modular. That means you can begin with one battery and add more later as your needs grow. For example, OCEAN Pro starts with 10 kWh and expands to 80 kWh. This is good for families who plan to:
  • Add EVs
  • Install more solar panels
  • Increase home size or number of appliances
Q4. Do solar battery systems help lower my energy bill?
A: Yes, they can. During the day, solar panels charge your battery. You can then use that stored power at night or during peak hours when grid power costs more. Some homes also join "virtual power plants" to sell extra power back. That adds extra savings or credits.
Q5. How long does the average power outage last in the U.S.?
A: In 2022, U.S. homes had an average of 5.5 hours of power interruptions over the year. This number includes major events like storms or wildfires. Without major events, the average outage time stayed close to 2 hours per year, which has been the trend since 2013. Some years were worse. In 2020 and 2017, outage times went above 7 hours due to more severe events.
For homes with important systems, like heating, cooling, or medical devices, even a short outage can cause trouble. That is why more families are choosing large solar battery systems for backup power.
Home Battery Backup
