Choose your country or region
How to Heat a Greenhouse: Sizing the Right Battery for Year-Round Growth
Modern greenhouse with solar panels on building roof demonstrating integrated battery heating system for sustainable year-round plant cultivation and energy independence.
Keeping a greenhouse warm through cold nights and freezing seasons is not just about turning on a heater. It requires a reliable, long-lasting energy system, especially if you're aiming for off-grid or backup-ready setups. That’s where the right greenhouse battery enters the equation. This article is designed for serious growers who manage mid- to large-size greenhouses and want real energy independence.
Why Greenhouse Heating Needs a Power Strategy, Not Just a Heater
Greenhouse heating consumes more energy than many growers expect. It’s a slow, constant battle with nature. Even slight temperature drops can stall plant growth or cause major losses.
The problem:
  • Temperatures drop drastically at night.
  • Electric heaters require large, steady power.
  • Power outages, grid limits, or remote locations make things worse.
Without a solid energy plan, you risk:
To stay productive year-round, you need a heating setup powered by a home battery system designed for this exact challenge.
How Much Energy Does a Greenhouse Heater Use per Day?
Before sizing a battery, understand how much energy you’ll need daily. Let’s break it down with an example:
Heater Power (Watts)
Runtime (Hours/day)
Daily Energy Need (kWh)
1000W
10
10 kWh
2000W
8
16 kWh
3000W
6
18 kWh
Other contributors to total load:
  • Ventilation fans: 1–3 kWh/day
  • Grow lights (winter use): 4–10 kWh/day
  • Humidity controllers or pumps: 2–5 kWh/day
A small greenhouse (under 200 sq. ft.) might use 5–10 kWh/day.
A mid-size greenhouse (200–600 sq. ft.) could easily need 15–30 kWh/day.
A large commercial greenhouse may exceed 40+ kWh/day in winter.
How to Size the Right Battery for Greenhouse Heating
You need a battery that handles your daily heating load, and still has energy left during emergencies or cloudy days.
Follow these steps:
Step 1: Total your daily kWh need. Include heating, lights, and other systems.
Step 2: Choose a battery with usable capacity ≥ total kWh.
Step 3: Add a 20–30% buffer for safety and inverter losses.
Step 4: Multiply by 2–3 days if you want off-grid backup.
Example:
If your daily need is 20 kWh, look for:
  • A system with 25–30 kWh usable storage for short-term heating.
  • 60–80 kWh total capacity for 2–3 days of full autonomy.
This is where high-capacity home battery systems, like the EcoFlow OCEAN Pro, can truly support your operation.
Can a Home Battery Really Power a Greenhouse Long-Term?
Many growers ask if batteries are just for short outages. The answer is no—large-capacity systems can fully power a greenhouse through entire winter cycles, as long as you:
  • Size the system based on real usage.
  • Pair it with solar for charging.
  • Use heating smartly (with thermostats and insulation).
Unlike backup generators, a home battery system can:
  • Run quietly.
  • Offer clean energy.
  • Reduce electricity costs with time-of-use shifting.
  • Automatically recharge with renewable sources.
What Temperature Should You Maintain in a Greenhouse Year-Round?
Plants thrive in specific temperature zones, especially in winter.
Crop Type
Ideal Temperature Range
Leafy Greens
50–70°F (10–21°C)
Tomatoes
60–80°F (15–27°C)
Peppers
65–85°F (18–29°C)
Orchids
70–90°F (21–32°C)
To hold these temperatures overnight:
  • Insulate windows and panels.
  • Use thermal mass (water barrels, rocks) to store heat.
  • Set smart thermostats to avoid overheating and waste.
Even with insulation, heaters need steady electricity, especially in areas below freezing.
Professional technician installing home battery storage system providing reliable greenhouse heating power supply for consistent temperature control and plant protection.
Which Heating Systems Pair Best with Home Battery Systems?
Electric heating can be efficient if matched correctly with battery power. Avoid high-initial-draw systems like large resistance heaters, unless your inverter supports it.
Battery-friendly heating options:
  • Infrared panels: low wattage, focused heating
  • Oil-filled radiators: steady heat, low power spikes
  • Heat pumps (for large greenhouses): efficient but inverter-dependent
  • Soil heating cables or mats
Use programmable timers and sensors to optimize usage and conserve battery charge.
The Best Time to Install a Greenhouse Battery System
Timing matters. Install during:
  • Late summer or early fall before winter demands begin.
  • Off-peak seasons—installers have more availability.
Why plan early?
  • Prevent winter energy shortages.
  • Avoid frozen soil affecting cable runs.
If you already use solar panels, syncing with a battery is a simple upgrade.
Why the EcoFlow OCEAN Pro Works Well for Greenhouse Energy Needs
For large-scale growers looking for stable heating and off-grid prep, the EcoFlow OCEAN Pro offers:
  • Up to 80 kWh of expandable capacity
  • IP67 outdoor-ready design
  • Seamless solar and generator charging
  • Real-time app monitoring to avoid downtime
Its stable power output and capacity make it a strong choice for heating-intensive environments, especially during extreme weather.
Heat Smart, Grow Smarter with the Right Greenhouse Battery
A warm greenhouse isn’t luck, it’s planning, sizing, and battery strategy. With rising energy costs and longer cold seasons, growers need more than just insulation. A well-designed home battery system gives control, comfort, and continuity.
Whether you're heating 100 or 1,000 square feet, the right energy storage makes all the difference.
And for large, outdoor-ready capacity, the EcoFlow OCEAN Pro proves itself as a dependable backbone.
Learn MoreGet a Quote
FAQs: Practical Answers for Greenhouse Battery Heating Systems
Q1. How long can a greenhouse run on battery power alone?
It depends on your setup. A small 5 kWh battery may run a mini greenhouse heater for a night. A 30–50 kWh system can power mid-size setups for 2–3 days, especially with good insulation. Larger greenhouses with high heat demands may still need a backup energy source for extreme cold spells or multi-day cloudy periods. To increase duration, growers often reduce heating runtime at night or use passive heat storage like water barrels. Battery runtime also depends on ambient temperature, heater efficiency, and system losses.
Q2. Can I use solar panels to charge the battery during the day?
Yes. Most modern battery systems are designed to pair with solar. During daylight hours, solar energy can recharge the system while powering fans or lights. In greenhouses with good solar exposure, solar charging can cover 70–100% of your winter energy needs when paired with the right panel array. Keep in mind, however, that solar generation drops on cloudy days, so oversizing panels or adding a hybrid inverter can make the system more reliable.
Q3. Is gas or electric heating better for battery use?
Electric heating is more battery-compatible since it integrates with renewable energy and is easier to automate. Gas heaters need venting and manual refueling. Electric systems can run on timers, sensors, and remote controls, making them easier to monitor and optimize. That said, they require careful battery sizing to avoid short runtimes. If your greenhouse is located in an area with limited solar gain, a hybrid approach (battery + passive solar or thermal mass) may work better.
Q4. What happens if my battery runs out overnight?
If the battery drains before morning, plant damage is possible. That’s why many users set backup triggers (like generator kick-ins) or choose larger battery banks. Running out of battery repeatedly also stresses the system and shortens battery lifespan. To avoid this, some growers set a low-battery threshold where only critical loads like heating mats stay on. You can also use predictive weather models to estimate charge needs ahead of freezing nights.
Q5. Are there any government incentives for using batteries in agriculture?
In many regions, yes. Programs like the USDA REAP (Rural Energy for America Program) often cover part of the installation cost for greenhouse energy upgrades. Local clean energy policies sometimes offer time-of-use rate discounts for battery systems that lower peak demand. Always check with local agricultural extension offices or clean energy boards for updates.
