Choose your country or region
Florida Electric Rates Are Rising: Should You Go Solar?
Electricity Bills Keep Rising. What’s Going On?
Across the country, more households are noticing that their electricity bills are climbing. Even though overall inflation is slowing, power prices continue to rise—and in some cases, they're rising by 4.5%, nearly twice the inflation.
Why is this happening? The answer isn’t just one thing. It’s a mix of rising demand, aging infrastructure, and new types of energy use that weren’t as common just a few years ago.
Demand Is Climbing Faster Than Expected
Electricity use in the U.S. stayed fairly flat for many years, mostly because appliances and lighting became more efficient. But that’s changing. More homes are using electric cars, smart tech, and heat pumps instead of gas systems. Population growth and energy-heavy businesses like crypto mining also add more pressure to the grid.
Another major factor is data. Modern data centers—those huge buildings full of servers—are using more and more power. Energy use from data centers tripled in the last decade and could double or triple again by 2028. If that happens, they could end up using around 12% of the nation’s total electricity. That’s more than the entire heavy industry sector combined, according to some energy analysts.
The Grid Can’t Keep Up
At the same time that demand is rising, the power grid itself is under stress. Many of the country’s transmission lines and transformers are decades old. Replacing or expanding them takes years, not months.
Some equipment, like transformers, used to be delivered in just a few weeks. Now, it can take two to three years. This slows down everything—from building new power lines to restoring service after storms. And since many of these parts are reaching the end of their life span, the system is more fragile than ever.
Federal targets call for major upgrades by 2030 and 2035, but current construction progress is far behind those goals.
Older Power Plants Are Going Offline
Many coal and natural gas power plants have shut down in recent years. While cleaner sources like wind and solar are growing, they haven’t filled the gap fast enough. When generation falls behind demand, prices tend to rise.
Building new facilities is also getting more expensive. Costs for wires, poles, labor, and materials like concrete and steel have all increased. Extreme weather adds more challenges. Hurricanes, floods, and wildfires cause damage that’s expensive to repair, and those costs often get passed on to customers.
The Cost of Electricity Varies by Region
Electricity is priced differently in each part of the country. Places like Hawaii and California often pay much more per kilowatt-hour than places like North Dakota or Washington. Some of this is due to how energy is produced or delivered locally, and some of it has to do with infrastructure.
Still, no matter where you live, electricity costs are trending upward nationwide.
How Much Does Electricity Cost in Florida in June 2025?
In June 2025, the average residential electricity rate in Florida is 15.09 cents per kilowatt-hour (kWh). This is about 2 cents lower than the national average, which stands at 17.11 cents per kWh. While Florida remains slightly more affordable than many states, rates can still face a new twist.
Florida Electric Rates May Go Up Soon
Although Florida’s current average residential electricity rate is slightly lower than the national average, prices are far from stable. In fact, electric bills in Florida may rise steadily over the next few years, especially if Florida Power & Light’s (FPL) proposed rate plan is approved.
FPL, the state’s largest utility, has submitted a four-year rate hike proposal to the Florida Public Service Commission. The plan would begin at the end of 2025 and continue through 2029. Under this proposal, residents in Northwest Florida could see an increase of $3.50 per month in 2026, rising to $8.39 per month by 2029. In Peninsular Florida, the increase is even steeper, reaching more than $17 per month by 2029.
In addition to these changes, FPL also wants to raise the minimum monthly base charge from $25 to $30. This means even households that use very little electricity will still pay more.
And these base rate increases don’t tell the full story. Other charges—such as fuel surcharges, nuclear cost recovery, storm repair fees, and grid upgrade costs—are not included in the rate proposal but still show up on monthly bills. These extra costs are also likely to rise.
A 3D floor plan of a modern home showcasing a complete EcoFlow energy solution, including solar panels on the roof, a home battery, and an electric vehicle charging in the garage.
Go Solar Now: A Smart Way to Control Your Power Costs
Florida is called the Sunshine State for a reason. There are many sunny days. That means solar panels can work well across the state. Even on cloudy days, panels still make power.
Many homes get enough sunlight to cover most of their daily energy use. If you install solar, you can lower your monthly bill and protect yourself from future rate hikes.
You Can Use Power from Your Roof
With solar, your home becomes your mini power station. When the sun is shining:
  • You generate your own power
  • You use less from the grid
  • Your meter moves slower (or even backward if net metering applies)
At night or on rainy days, you still pull energy from the grid. But over the full month, your bill can drop a lot. You pay less because you rely more on your roof—and less on the power company.
Solar Batteries Add Extra Freedom
If you pair solar panels with a battery, you can store energy for later. This helps:
  • When the grid goes down
  • On cloudy or rainy days
  • During the night
  • Get total energy independence
One strong option is the EcoFlow OCEAN Pro. It holds up to 80 kWh of power. That’s enough to run your whole house for days. It can handle large appliances like air conditioners, water heaters, and even EV chargers.
It charges fast from the sun—with support for up to 40kW of solar input—and keeps your home running even during long outages. You don’t need a gas generator. And you don’t have to worry about power loss during storms.
The EcoFlow OCEAN Pro is also built for hot, wet weather. It works in Florida heat (up to 140°F) and is flood-resistant up to 2.6 feet. It’s made for real Florida homes, not just perfect weather.
Learn MoreGet a Quote
Incentives Are Still Available
Some cities and counties in Florida offer extra rebates or solar programs. These help cut your upfront cost even more. Check with your local utility or government office to learn what’s available in your area.
A modern white home with solar panels, featuring an EcoFlow home battery and generator installed neatly on the side of the house.
Why Now
Electricity prices keep going up. Storms keep getting stronger. The power grid is not always reliable. Solar gives you more control. A smart system with battery storage keeps your home safe, lowers your bill, and makes your energy future more stable.
The sun shines for free. You just need the right tools to use it. Solar panels and smart batteries like the EcoFlow OCEAN Pro turn sunlight into power and power into savings.
If you live in Florida, please call us now.
Cost & Savings
