Solar Panel Cleaning Near Me: Costs, Methods and When You Need It
Most UK homeowners pay somewhere between £80 and £180 for a professional solar panel clean, depending on the size of the array, how easy it is to get to, and the roof pitch. British rain will shift loose dust, but stubborn grime, bird muck, pollen, and other gunk can eat into your output. How much of a hit you take depends on what’s built up, the angle of your panels, local conditions, and your system setup, so it’s best to clean when you can see it’s mucky or you notice a drop in performance.
This guide covers when your panels actually need to be cleaned, what it costs in the UK, safe ways to do it yourself, and how to pick a decent local pro to keep your solar setup running at its best.
Key Takeaways
Rain on its own isn't always enough. British showers wash off loose dust, but they leave behind oily traffic grime, lichen, and bird droppings that bake on over time.
For a typical 10- to 16-panel home setup, you're looking at about £100 to £150 for a professional clean with pure water-fed poles.
Safety first, and mind your warranty. Avoid the abrasive stuff, tap water, or pressure washers, they'll crack the glass, mess up the coating, and wipe out your guarantee.
Once the panels are clean, team them up with smart monitoring and battery storage, and you'll actually hold onto every extra unit they generate.
.png)
How Can You Tell If Your Solar Panels Need Cleaning?
A light layer of everyday dust usually isn’t anything to worry about. But once grime starts building up properly, it’ll quietly eat into your daily generation figures before you even notice.
Visual Signs of Dirt and Debris
Grab a pair of binoculars and have a squint from ground level, you'll usually clock the problem straight off:
Bird muck: pigeons and gulls love roosting up near the panels, leaving behind thick, crusty patches that block the light from getting through.
Moss and lichen: A proper nuisance in damp, shady parts of the UK. It creeps along the edges of the frames and holds moisture against the seals.
Dried-on streaks: After a light shower or a dewy morning, you'll often spot dark, sooty tide marks along the bottom edge of the glass.
Performance Drops and Efficiency Loss
Pick a clear, sunny day and check your inverter screen or monitoring app. If your system’s output looks noticeably lower than it normally does in similar weather and conditions, dirt could be playing a part. But don’t jump to conclusions—shading, high panel temperatures, inverter faults, grid limits, or general equipment wear can all knock your generation too. So a dip in performance doesn’t always mean your panels need a clean.
How Much Does Solar Panel Cleaning Cost in the UK?
What you pay for solar panel cleaning in the UK really depends on the size of your system, how high it is, and whether the job needs extra gear like a cherry picker or scaffolding.
If cleaning is part of a wider upgrade, compare it with the full install solar panels cost so you can budget for scaffolding, access and maintenance together.
Average Solar Panel Cleaning Costs for UK Homes
Most decent window and exterior cleaning firms use water-fed telescopic poles from ground level, which keeps the labour costs fairly sensible.
| System Size / Property Type | Typical Number of Panels | Estimated Cost Range (UK) | Average Service Time |
| Small Array (Bungalow / 1-Storey) | 6 – 8 panels | £60 – £90 | 45 – 60 mins |
| Standard Domestic (2-Storey Semi/Detached) | 10 – 14 panels | £90 – £140 | 1 – 1.5 hours |
| Large Domestic (2 to 3-Storey Detached) | 16 – 20+ panels | £140 – £220 | 1.5 – 2.5 hours |
| Complex Access (Steep Pitch / 3+ Storeys) | Any size requiring boom lift | £250 – £450+ | 2 – 4 hours |
The costs listed above are typical market estimates based on industry averages as of 2026. Actual quotes may vary depending on your location, the specific provider, and site conditions—always request a bespoke quote for the most accurate pricing.
Add-ons Available During Your Solar Panel Clean
Bundling a few extra roof jobs into the same visit can often reduce the overall cost. You could add bird-proofing mesh, with stainless-steel skirts fitted around the panel edges to prevent pigeons from nesting underneath, typically costing around £250 to £550. It is also worth arranging gutter clearance while the installer is already working at roof level, with gutters and downpipes usually vacuumed for an additional £40 to £80. For longer-term maintenance, you can also consider anti-fungal glass treatments, which use solar-safe coatings to help slow the return of moss and lichen.
What Solar Panel Cleaning Methods Are Safe and Effective?
PV glass has micro-textured anti-reflective coatings and delicate silicone seals round the edges, so it needs gentle, non-abrasive washing methods.
Manual Cleaning for Residential Panels
For most homes, the most common and recommended way to clean panels is from the ground using soft, scratch-free telescopic brushes and pure de-ionised water. The pure water lifts the dirt on its own, then evaporates without leaving any limescale or streaks behind.
Professional Methods for Difficult Roof Access
When panels sit on steep pitches, dormers, or high commercial roofs, certified technicians use:
Mobile cherry pickers (MEWPs):
Get a cherry picker in place, giving you a stable platform alongside or above the roof—so you can reach the panels without putting weight on tiles or the glass. Handy for steep roofs, high buildings, or anywhere ladders just won’t cut it. The machine needs to sit on firm, level ground, and you want someone who’s properly trained running it.
Low-pressure, high-flow van-mounted systems:
For panels that are awkward to reach, the team can work from the ground with telescopic carbon-fibre poles running off a van-mounted water system. These setups push a controlled flow of heated or purified water straight up to the roof—saves messing about with ladders or clambering up there. Use deionised or ultra-pure water with it, and it’ll lift the dirt and bird muck without leaving mineral spots behind as it dries.
Specialised rotating solar wash brushes:
Water-driven rotating brushes are made for PV panels—cover big arrays way more evenly than hand scrubbing. Low torque, so they loosen bird muck and stubborn crud without needing to lean into it. On large commercial jobs, that means quicker work and a cleaner finish across the board.
Roof-edge and fall-protection systems:
If the job does mean getting up on the roof, decent contractors will put proper fall protection in place—edge protection, roof anchors, harnesses, scaffolding, whatever the job needs. What they actually use depends on the roof, how high it is, the pitch, and what they’re dealing with on site. The aim is to stop anyone taking a spill, while keeping contact with the panels themselves to a minimum.
Safe Techniques to Avoid Panel Damage
To prevent irreversible cell damage and maintain system longevity, always enforce these safety rules:
Avoid high-pressure jet washers
Too much water pressure or getting the technique wrong can do real damage to the panel surface, seals, or frames. It can also go against manufacturer guidelines, and if something does get broken, you could end up voiding your warranty.
Avoid untreated tap water in hard-water areas
Hard water leaves limescale and other marks on the glass as it dries, which over time can reduce light getting through and make panels harder to clean the next time around. That’s why pure or de-ionised water is the standard—it dries completely spot-free.
Avoid harsh chemicals and abrasive tools
Bleach, strong acids, scouring pads, or any harsh cleaning gear can ruin the glass or its coatings. The recommended approach is to stick with what the panel manufacturer recommends—that way you avoid damage and keep your warranty intact.
Clean panels when they are relatively cool
Early morning, late afternoon, or a cloudy day is usually the best time. Try not to splash cold water on panels that are baking hot, sudden temperature changes can put unnecessary stress on the glass and the rest of the unit.
How Do You Choose a Solar Panel Cleaning Service Near You?
Hiring an experienced specialist prevents costly roof damage and ensures your manufacturer warranty remains fully protected.
When comparing providers, check whether the installer can explain the MCS certificate requirements that apply to the wider solar system, especially if repairs or electrical work are also needed.
Compare Local Quotes and Services
Get itemised written quotes from two or three local exterior cleaning companies. Make sure each one spells out whether they use de-ionised pure water and whether a quick visual check of the wiring and frames is part of the price.
Check Reviews and Previous Cleaning Experience
Find someone who actually specialises in solar panel cleaning, not a general handyman. Have a flick through recent customer photos on Checkatrade, Trustpilot, or Google Maps to see proof of domestic rooftop work, and make sure they’ve got proper experience handling PV glass and solar panels—not just standard windows.
What Else Should You Check During Solar Panel Maintenance?
A panel wash provides an ideal opportunity to inspect your entire rooftop and internal electrical setup for early signs of wear.
Inspect Mounting Systems and External Components
While the technician’s up there cleaning your panels, ask them to give the mounting framework a quick once-over. They should keep an eye out for any loose roof brackets, corroded clamps, wind-lifted flashings, or damaged bird netting around the edges of the array.
Check Electrical Connections and Inverter Operation
Head inside and take a look at your inverter and isolator switches. Make sure the cooling fins aren’t clogged with household dust, and check there are no amber or red warning lights showing. Give the DC isolator switch housings a once-over too, they should be clean, with no signs of heat damage or damp getting in.
Monitor Solar Performance Between Maintenance Checks
Once your panels are clean, keep an eye on generation over the next few days and compare it with similar weather and seasonal conditions. Your inverter or monitoring app will show any changes in daily output, though bear in mind, it’ll naturally go up and down with sunlight and temperature.
For those who want a closer look, a smart management console like the EcoFlow PowerInsight 2 gives you real-time data on generation, household usage, and where the power’s going. Makes it dead easy to see what difference the clean has actually made.
A connected Home Energy Ecosystem can bring solar generation, monitoring and household consumption into one view, making post-cleaning performance easier to track.
Optimise Energy Use After Regular Maintenance
Pairing clean PV generation with an EcoFlow Home Battery can increase self-consumption by storing surplus daytime energy for later use.
Regular cleaning stops you losing generation to a build-up of muck. Once your panels are running at full tilt, the next move is making sure you actually use all that extra power. For UK households looking to cut ties with the grid as much as possible, adding a home battery, like the Ecoflow OCEAN 2 Plus single phase, lets you stash daytime solar to run the kettle, oven, or washing machine during peak evening rates, or sell the surplus back through the Smart Export Guarantee.
Keeping your solar panels clean is one of the easiest ways to protect your generation and save on your energy bills. Rain will wash off loose dust, but bird muck, traffic grime, and moss need proper dealing with. Get a local insured pro with pure water-fed poles every year or two, keep your warranty intact, your roof safe, and your panels pumping out clean electricity year after year.
Can dirty solar panels cause permanent damage?
Yes, heavily soiled spots like baked-on bird droppings create persistent “hot spots” where shaded cells heat up excessively, potentially causing permanent degradation to the panel’s internal semiconductor layers over time.
Does rainfall clean solar panels automatically?
Not really. Rain will shift light dust, but it won’t touch sticky traffic grime, bird droppings, pollen, or lichen. Think of it like a dirty car windscreen—you need a bit of elbow grease to actually get it clean.
What voids a solar panel warranty?
Plenty of things. Using abrasive or chemical cleaners, blasting them with a pressure washer, walking on the panels, or shocking hot glass with cold water can all invalidate your manufacturer’s warranty.
Should I turn off solar panels before cleaning them?
Follow the manufacturer’s cleaning and shutdown guidance before cleaning your solar panels. If the system needs to be isolated or you are unsure about the correct procedure, contact a qualified solar professional rather than handling electrical components yourself.
