RTS Switch Off in UK: How Homeowners Can Prepare for Smarter Energy Control
The Radio Teleswitch Service (RTS) switch off refers to the permanent withdrawal of the long-wave radio signals that control off-peak electricity meters and related heating systems in affected UK homes. If your home relies on an RTS meter for Economy 7, Economy 10, storage heaters, or electric hot water, your system may no longer switch correctly between tariff periods, potentially affecting heating schedules, hot water availability, and electricity costs. UK energy suppliers are replacing affected RTS meters with modern smart meters at no additional cost to customers, helping households maintain accurate tariff management and reliable energy controls.
Key Takeaways
Widespread Impact: The RTS switch‑off directly affects UK households running Radio Teleswitch Service meters, especially those reliant on legacy radio signals for off‑peak heating, hot water schedules, and multi‑rate tariffs.
Smart Meter Replacement: Energy suppliers are actively replacing RTS meters with smart meters (SMETS2) to keep tariff control running smoothly and maintain reliable service.
Immediate Action Required: Homeowners should check their electricity meter, confirm their setup with their supplier, and book a replacement smart meter installation before RTS controls are withdrawn in your area.
Future‑Proofing Beyond Smart Meters: Moving away from fixed RTS schedules opens the door for households to pair smart meters with solar PV and home battery storage, giving them greater visibility and control over their energy costs.
What Is the RTS Switch Off and How Does It Affect UK Energy Users?
The RTS switch off affects how some UK homes receive off-peak electricity. Knowing whether your meter relies on this system can help you avoid heating and hot water problems.
The Role of Radio Teleswitch Service in Older UK Energy Systems
For over 40 years, the Radio Teleswitch Service (RTS) has quietly managed variable-rate electricity for homes across Great Britain. Introduced in the 1980s, it works by sending control signals through the BBC Radio 4 Long Wave transmission service from the Droitwich transmitter. These signals tell compatible meters when to switch between peak daytime rates and cheaper off-peak night rates.
When the signal hits an RTS meter at night, it clicks over to the discounted rate and kicks on heavy‑load appliances like storage heaters and immersion hot water cylinders. This allowed UK households without mains gas to charge their thermal storage systems overnight using cheaper electricity.
Reasons Behind the UK Transition From RTS to Smart Meters
The RTS system is being replaced because the technology behind it is becoming outdated. Several factors have sped up the move to smart meters.
BBC Radio 4 Long-Wave Service Changes: The BBC’s long‑wave transmitters rely on ageing long-wave transmission equipment that is becoming increasingly difficult and costly to maintain.
Ofgem & UK Government Energy Policy: Energy regulator Ofgem and industry organisations have supported the transition away from legacy teleswitch meters, with suppliers responsible for arranging replacements.
Smart Meter Rollout Progress: The UK’s smart meter rollout offers a modern, cellular‑based alternative through the DCC network. It gives two‑way communication, real‑time readings, and much better reliability.
Energy Services Affected by RTS Signal Shutdown
Homes that still use RTS meters may experience problems with heating, hot water, or off-peak tariffs after the signal ends.
Heating Stuck On or Off: Electric storage heaters may fail to charge overnight, potentially leaving homes colder during winter, or remain continuously powered on, potentially causing unnecessary heating costs and higher electricity bills.
Hot Water Disruption: Immersion heaters connected to off-peak circuits may cease heating water automatically.
Tariff Misallocation: Multi-rate meters (such as Economy 7 or Economy 10) may freeze on a single rate, causing energy suppliers to charge all electricity consumption at the standard daytime tariff. This unexpected change in billing is one reason some households may ask why their electric bill is so high, as electricity usage that was previously charged at cheaper off-peak rates could suddenly be billed at standard rates.
RTS Switch Off Timeline and Key Dates for UK Households
Energy suppliers have been systematically contacting affected customers to schedule priority smart meter replacements. Below is a summary of key operational milestones across the UK grid:
| Phase / Timeline | Key Operational Milestone | Impact on UK Homeowners |
| Phase 1: Customer Contact | Energy suppliers identify RTS meter serial numbers and contact account holders. | Homeowners receive letters/emails urging them to book an urgent smart meter replacement. |
| Phase 2: Priority Installations | Engineers prioritize vulnerable households and off-peak heating users across Scotland, Wales, and England. | Free SMETS2 smart meter installations carried out; old teleswitch gear decommissioned. |
| Phase 3: Completion of RTS Replacement Programme | RTS broadcasts through the long-wave transmission service are permanently withdrawn. | Unreplaced RTS meters lose automatic switching, locking meters in arbitrary states. |
What Should UK Homeowners Do Before the RTS Switch Off?
Checking your meter early and contacting your supplier can help prevent service interruptions.
How Can I Check If My Home Uses an RTS Meter?
Not sure whether your home uses RTS? Start by checking your electricity meter and energy bill.
Look for a Separate Switch Box: RTS setups often feature a separate small plastic unit mounted alongside the main meter, clearly labeled “Radio Teleswitch”, “RTS”, or bearing the BBC logo.
Check Meter Markings: Many older digital or dial meters indicate multi-rate tariff capability with physical switches labeled “Day” and “Night” controlled by radio signals.
Review Your Energy Bill: If your bill shows distinct tariff rates (e.g., Economy 7 / Total Heating Total Control / Domestic Economy) and you do not have an in-home smart meter display, you likely have an RTS setup.
What Happens If My RTS Meter Is Not Replaced Before the Shutdown?
An unreplaced RTS meter may no longer switch between rates or control heating correctly after the signal ends. If it freezes in the “off” position, your storage heaters or hot water cylinder may not receive the expected off-peak electricity supply overnight. If it freezes in the “on” position, your heating system will run continuously during peak daylight hours, potentially leading to significantly higher electricity bills.
When Should I Contact My Energy Supplier for a Smart Meter Upgrade?
Contact your supplier as soon as possible if you think your home uses an RTS meter. Arranging a smart meter installation before the deadline can help avoid delays, as suppliers are prioritising households affected by the RTS switch off, especially those relying on electric heating or off-peak tariffs.
Contacting Your Supplier: Call your supplier’s dedicated meter replacement hotline or request an upgrade via your online portal. Emphasise if you rely on electric heating.
Installation Timeframe: Appointment availability varies by supplier and location, with some households receiving installations within weeks depending on engineer availability.
Recommended Action Deadline: Booking early before local replacement deadlines can help reduce the risk of delays, especially during periods of high demand.
Which UK Homes Are Most Affected by the RTS Switch Off?
The households facing the highest impact are off-gas-grid properties. This includes rural homes in Scotland, North Wales, Cornwall, and rural England, as well as high-rise urban flats built in the 1970s–1990s utilizing electric storage heating, wet radiator systems driven by off-peak boilers, or complex multi-meter tariffs like Total Heating Total Control (THTC).
How Can Homeowners Build More Flexible Energy Systems After RTS Replacement?
A smart meter solves the RTS issue, but homeowners can also use this opportunity to improve how they generate and store electricity.
The Limits of Smart Meters for Long-Term Energy Cost Control
While a modern SMETS2 smart meter successfully replaces outdated radio signals, a smart meter alone does not reduce your overall kilowatt-hour consumption or lower grid energy rates. It simply records detailed usage data and allows your energy supplier to charge you based on dynamic pricing. To reduce exposure to high UK grid prices, homeowners need active energy generation and storage assets rather than relying only on consumption monitoring. A complete Home Energy Ecosystem combines smart meters, solar generation, battery storage, and connected home devices to help households move from passive energy monitoring to active energy optimisation.
Using Solar and Battery Storage to Reduce Reliance on Grid Scheduling
As the rigid RTS system phases out, domestic energy management is shifting from fixed time-based controls to proactive home energy ecosystems powered by solar PV, battery storage, and intelligent automation. Rather than relying solely on arbitrary overnight heating windows dictated by utility companies, UK households can now store self-generated solar power or low-cost off-peak electricity for use during expensive evening peak hours.
For instance, robust home battery energy storage systems like the EcoFlow OCEAN 2 Plus Single Phase allow UK households to store larger amounts of usable electricity. By automatically charging during off-peak windows or capturing excess rooftop solar power during the day, this battery system can help reduce reliance on higher-cost grid electricity during peak periods—supporting the transition from fixed RTS schedules towards more flexible home energy management.
Improving Household Energy Decisions Through Real-Time Monitoring
Following an RTS meter replacement, smart meters log highly granular usage data. However, data is only useful if homeowners can act upon it. To make smart tariff choices work in your favour, you need full visibility over when your rooftop solar is generating, when your home battery is charging or discharging, and which household appliances are drawing heavy loads.
In this context, centralized visual controllers like the EcoFlow PowerInsight 2 can act as a smart home energy management interface. Displaying real-time power flows, battery states, and consumption analytics through an intuitive touchscreen display, it helps UK households make more informed energy decisions as the UK’s flexible energy market evolves.
.png)
How Can Smart Energy Management Help Reduce Future UK Electricity Costs?
Moving away from fixed radio controls opens up the potential for flexible, market‑driven electricity management that can cut annual household energy bills.
Moving From Fixed Time-Based Control to Smarter Energy Optimisation
Traditional RTS controls operated on rigid, one-way schedules—for example, switching on strictly between 12:00 AM and 7:00 AM. Modern smart energy management systems optimize electricity usage dynamically by comparing live household demand, real-time battery storage levels, and fluctuating hourly grid pricing.
Preparing for Flexible Tariffs and Changing Electricity Prices
With frequent adjustments to the Ofgem Price Cap, UK energy costs remain subject to wholesale market volatility. In response, UK energy suppliers are launching innovative dynamic time-of-use (TOU) tariffs (such as Octopus Agile or Intelligent Octopus). These tariffs offer ultra-cheap rates when offshore wind generation is high, and higher rates during peak evening demands (4:00 PM – 7:00 PM). Combining smart meters with home battery storage allows households to store cheaper electricity and avoid higher peak rates. As UK households move away from fixed RTS schedules, solutions such as an EcoFlow Solar Battery can help store excess solar generation or lower-cost electricity and release it when grid prices rise, giving homeowners more control over future energy costs.
Traditional RTS Control vs Modern Smart Energy Management
The contrast between legacy RTS technology and modern smart energy management highlights why the current national transition is ultimately advantageous for homeowners:
| Feature / Capability | Legacy RTS System (1980s Tech) | Modern Smart Energy Management |
| Communication Mode | One-way radio signal (BBC Radio 4 Long Wave 198 kHz) | Two-way secure cellular/DCC smart network |
| Tariff Flexibility | Fixed off-peak windows (e.g. rigid 7 hours) | Dynamic time-of-use tariffs and more flexible pricing options |
| Household Visibility | None (basic electromechanical dial reading) | Live dashboard, app monitoring & historical data |
| Solar & Battery Integration | Limited integration; often requires additional controls | Fully automated AI charging & solar optimization |
| Reliability & Support | Ageing hardware; being gradually retired | Supported digital infrastructure with ongoing rollout |
The RTS shutdown is a practical change for thousands of UK households, especially those using electric heating, storage heaters, or older off‑peak tariffs. Replacing an affected meter is the first step to keeping your heating and hot water running reliably.
However, moving to a smart meter also creates new opportunities to manage electricity more efficiently. When combined with flexible tariffs, solar generation, and battery storage such as the EcoFlow OCEAN 2 Plus Single Phase, homeowners can better decide when to use, store, and buy electricity. With tools like the EcoFlow PowerInsight 2, households can gain clearer visibility into their energy consumption and make smarter decisions as the UK energy market continues to evolve.
Disclaimer: RTS replacement timelines, smart meter installation processes, energy tariffs, and available energy solutions may change over time. The information in this article is provided for general guidance only and does not replace advice from your energy supplier or qualified installers. We recommend contacting your energy supplier directly to confirm your RTS meter replacement arrangements and checking official guidance before making decisions about home energy upgrades.
How do I know if my off-peak heating system depends on RTS?
Check your electricity meter box for a secondary switch unit marked ‘Radio Teleswitch’ or ‘RTS’, or review your energy statement to see if your off-peak heating (such as Economy 7 or THTC) switches automatically without a digital programmer on the meter itself.
What happens to my heating and hot water if my meter isn't replaced in time?
Your off-peak heating and hot water control switches may stop switching correctly or remain stuck in the last programmed state when the radio signal is decommissioned, which means your heating may get permanently stuck on peak rates or may fail to switch on during the expected off-peak period.
Will my solar export payments be affected by the RTS switch off?
Your Smart Export Guarantee (SEG) payments won’t be directly stopped by the RTS signal shutdown, but upgrading to a modern SMETS2 smart meter is essential for accurate export readings and managing SEG payments correctly.
Can battery storage help after RTS meter replacement?
Yes, installing a domestic battery storage system allows you to store cheap off-peak grid electricity or excess solar power, giving you greater flexibility beyond traditional fixed utility schedules and potentially reducing reliance on higher-cost grid electricity.
Who is responsible for arranging my meter replacement?
Your energy supplier is legally responsible for arranging and funding your RTS meter replacement, and eligible customers should receive a replacement smart meter at no additional cost.
