Choose your country or region
LiFePO4 vs Lithium Ion: What’s the Difference?
LiFePO4 and Lithium-ion batteries are two popular rechargeable battery chemistries. Although these terms might sound similar, they’re actually entirely different batteries. Confused yet? You’re not alone.
We’re here to dispel the myths and clarify what differentiates these two battery types. We'll also provide insight into what to consider when choosing a battery and how to determine whether LiFePO4 batteries or lithium-ion batteries are right for you and your use case.
What is a LiFePO4 Battery?
LiFePO4 batteries stand for Lithium Iron Phosphate, which describes their unique cathode chemistry. The anode is typically carbon or graphite-based. This type of battery is known for its enhanced safety profile and long lifespan, thanks to high stability (which resists overheating and fire risks) and extensive cycle life of up to 5,000+ charge/discharge cycles. LiFePO4 batteries also have built-in short-circuit and overcharge prevention, adding to their safety features.
These batteries are also safe for the environment. They’re made of non-toxic materials and don’t include any cobalt, making them an eco-friendly option.
They’re a good choice for extreme environments, as they perform well in high temperatures, where other battery chemistries may struggle. It makes them great for solar storage, home backup power systems like the EcoFlow PowerOcean (Single-Phase), or RV use.
What is a Lithium-Ion Battery?
Lithium-ion batteries have been the go-to for many years and are still common in modern electronics and electric vehicles. Still, they’re starting to get phased out by LiFePO4 batteries, which have improved upon some Li-ion challenges.
Their high energy density works well in EVs because they can pack a lot of power in a small, compact size and relatively light weight. They’re also commonly used in smartphones, laptops, and power tools.
A lithium-ion battery usually uses a graphite anode, but the cathode materials vary widely, from Nickel Manganese Cobalt Oxide (NMC, common in EVs) to Lithium Titanate.
The downsides of Lithium-ion batteries include a greater risk of thermal runaway, overheating, or catching fire, greater sensitivity to extreme hot or cold temperatures, and only a moderate cycle life of 500-1,000 charge/discharge cycles.
EcoFlow Image
LiFePO4 vs Li-ion: 6 Differences
  • Chemistry: LiFePo4 chemistry is more environmentally friendly, as it uses lithium iron phosphate, which is non-toxic, while Li-ion often uses cobalt, nickel, and manganese/aluminium. These materials are more toxic, expensive, and may be sourced unethically.
  • Energy Density: Li-ion has a higher energy density, making it ideal for applications where space and weight matter, like EVs. LiFePO4’s lower energy density will take up more space for the same battery capacity.
  • Safety: LiFePO4 is much more thermally stable and safer, while Li-ion can overheat or catch on fire if it overcharges or overheats.
  • Cost: You’ll pay more upfront for a LiFePO4 battery, but you will see better value in the long term because of their longer lifespan. On the other hand, Li-ion batteries are cheaper upfront but will need more frequent replacement, creating a higher cost over time.
  • Use Cases: Li-ion is ideal for EVs, mobile electronics, and other applications where high output and compact size are needed, while LiFePO4 batteries work perfectly for adding a battery to an existing solar storage or EcoFlow Home Battery, RVs, and backup power applications where size and weight aren’t determining factors.
  • Cycle Life: Li-ion’s cycle life is usually around 500-1,000 cycles before it starts to degrade, which is short compared to LiFePO4’s 2,000-5,000 cycle life.
EcoFlow Image
What to Consider When Choosing the Right Battery
  • Type: Chemistry should be your first consideration, because it dictates several other factors. For example, choosing LiFePO4 chemistry means you’ll get a longer cycle life and better safety profile. However, Li-ion batteries have a more compact size and lower initial cost.
  • Capacity: The battery capacity, measured in Wh or Ah, tells you the amount of energy the battery can store. You’ll need to ensure the battery can meet your energy needs. To determine this, add the wattage of all the appliances you want to run with the battery, then multiply it by how many hours you plan to use them. Verify that the battery’s capacity is greater than this number in Wh.
  • Voltage: You need a battery that is compatible with your device. Voltage is usually 12V, 24V, or 48V.
  • Cycle Life: The longer the cycle life, the more charge/discharge cycles your battery will handle before it begins to degrade and lose power quicker after each charge. A higher cycle life means a better investment in the long term.
  • Safety: Look for battery safety features, like overcharge and overheat protection, short circuit prevention, or an internal battery management system (BMS). Between the LiFePO4 and Li-ion battery, the LiFePO4 is safer.
  • Operating Conditions: How well can the battery perform in cold temperatures? What about extreme heat? If you plan to use the battery only in moderate conditions, this won’t matter much, but if you want to use it outdoors or take it on adventures, flexible temperature performance matters.
  • Portability: Size and weight matter for mobile setups or when space is limited, such as in an RV, on a boat, or when choosing a portable power station. The higher the energy density of a battery, the more power it will pack in a smaller size. If portability doesn’t matter, such as in a stationary solar battery, you can choose a heavier option that packs more power.
  • Budget/Value: There’s more to consider than just upfront cost. You must also think about the lifespan and cost per cycle. For example, LiFePO4 is more expensive upfront than Li-ion, but it lasts longer with fewer replacements, ultimately saving you money over time.
Is LiFePO4 the Same as Lithium-ion?
LiFePO4 is a type of lithium-ion battery, but not all lithium-ion batteries have LiFePO4 chemistry. Lithium-ion is an umbrella term for a broad category of rechargeable batteries that use lithium ions travelling between electrodes to create power.
Which is Better, LiFePO4 or lithium-ion?
It’s hard to say one is categorically better than the other; it depends on the application. LiFePO4 is better when stability, safety, lifespan, and temperature tolerance are essential, while Lithium-ion is better for energy density, size, and cost.
While lithium-ion and LiFePO4 batteries have some similarities, these two battery chemistries are each ideal for unique scenarios. Lithium-ion tends to be a better choice for compact, high-power, and portable applications, while LiFePO4 performs better when durability, safety, and lifespan are prioritised.
All EcoFlow products, including the EcoFlow PowerOcean (Three-Phase) home battery, use LiFePO4 batteries because of their distinct advantages.
