Choose your country or region
How Long Does It Take for Solar Panels To Pay for Themselves
If you’re considering installing solar panels at home, you probably know they can save you significant money on energy bills.
One of the most significant advantages of using a renewable energy source like solar power is that there are no ongoing fuel costs.
Once you’ve achieved solar payback through energy bill savings, your investment in solar panels really starts paying off…
But how long does the average solar payback period take?
Read on to find out.
EcoFlow Image
What Is the Average Payback Period for Solar Panels?
The solar payback period is the length of time it takes for you to recoup the total purchase and installation costs of photovoltaic (PV) modules — like solar panels or shingles — and the balance of system components required to generate and output household (AC) electricity.
Off-grid and hybrid PV systems that generate and store electricity from sunlight must include the following components.
  • PV modules
  • Solar inverter
  • Solar battery
  • Charge controller
  • Battery management system
Battery storage is optional in grid-connected systems, but without a battery, the system will automatically shut down during a blackout, leaving you without power for the duration of the outage.
Many factors influence how long the solar payback period takes, so the averages have quite a wide range.
As a general rule of thumb, most residential solar power systems pay for themselves in under 10 years.
High-quality PV modules last up to 30 years, giving you approximately two decades of “free” electricity — and a significant return on investment.
The Energy Saving Trust estimates that a 4kW solar panel system in the UK provides an ROI of 4-8% per year over its 25 to 30-year lifespan.
Average Solar Payback Period and Energy Bill Savings by System Size (UK)
EcoFlow Image
The estimates above are for grid-tied solar power systems without home battery storage.
On-grid systems are designed to supplement electricity from the National Grid, not replace it.
Investing in a hybrid PV system with solar battery storage — such as EcoFlow PowerOcean — requires more investment upfront but significantly increases your energy bill savings.
It can even eliminate electricity costs altogether.
What Factors Affect the Payback Period for Solar Panels?
Residential photovoltaic systems pay for themselves primarily through energy bill savings, but many factors influence how long the solar payback period will take, given the particulars of your installation.
Current Electricity Consumption
The most accurate way to determine the number of solar panels and what type of system you need is to assess your household electricity consumption in kilowatt-hours and the electricity requirements of the appliances you want to be able to start and run simultaneously.
If you’re planning to install a grid-tied solar panel system without battery storage, you’ll continue to use National Grid power when your electricity consumption exceeds the amount of power your PV modules can supply — including every night.
Your solar panels will supplement grid power, not replace it, which can still save you a significant amount on energy bills.
However, if you’re looking to go fully off-grid or increase self-consumption by storing the electricity your solar panels generate in a home battery for later use, it’s essential to ensure your AC output (watts/kilowatts) and storage capacity (watt-hours/kilowatt-hours) are sufficient to meet your requirements.
The most accurate way to determine how much output and storage you need to run your home is to total the starting and running watts of the appliances, devices, and home systems you want to run simultaneously (W/kW), estimate how long you want to run them for (Wh/kWh) and use the data to determine what size your system must be to meet your electricity generation goals.
ApplianceRated (Running) Watts Starting Watts
Dishwasher13001800
Washing Machine 1200 2300
Refrigerator/Freezer 7002200
Light Bulb 60-750
Microwave 600-10000
TV5000
Toaster9000
Vacuum1440 2500
Coffee Maker1000 0
Blender300 800
Clothing Iron 1500 0
Dryer 5400 7000
Toaster Oven 1200 0
Curling Iron 1500 0
Space Heater 2000 0
Laptop 50-300 0
20” Box Fan 200350
System and Installation Costs
The total purchase and installation costs of your solar panels and the balance of system are determining factors in how long it will take to achieve solar payback.
You won’t begin seeing a financial return on your solar investment until your system is paid off.
Include finance charges, interest, or any other costs related to the purchase and installation of your photovoltaic system to get an accurate picture of when you’ve recouped your investment.
While it may be tempting to purchase the cheapest available solar panels and balance of system parts that meet your electricity generation targets, it’s essential to understand that PV modules and components like solar inverters and batteries are not created equal.
For example, polycrystalline solar panels are typically less expensive than those that use pure monocrystalline silicon photovoltaic cells, but they’re also much less efficient.
Solar panel efficiency measures how much electricity is generated per square meter (m2) of photovoltaic material.
Monocrystalline solar panels can achieve up to 25% efficiency ratings, while polycrystalline PV modules top out at about 18%.
In this case, a 400W poly solar panel with an efficiency rating of 18% would have to be almost 40% larger than a 400W mono solar panel with an efficiency rating of 25%.
The efficiency of PV modules directly impacts the installation surface area required and the number of solar panels needed to reach your electricity generation goals.
For off-grid and hybrid solar generators with storage, battery chemistry plays an essential role in determining longevity and performance.
Here are the most frequently used battery chemistries for photovoltaic applications in ascending order of lifespan and performance (from worst to best).
● Flooded lead-acid
● Sealed lead-acid (SLA)/Valve-regulated lead-acid (VRLA)
● SLA and VRLA solar batteries are frequently marketed as deep-cycle, dry, or maintenance-free. Two primary subtypes differ chemically but offer similar performance.
  • Gel cell (gel)
  • Absorbent glass mat (AGM)
● Lithium-ion (Li-ion)
  • Lithium nickel manganese cobalt oxides (NMC, Li-NMC, LNMC, or NCM)
  • Lithium iron phosphate (LFP/LiFePO4)
Carefully assess your mid-to-long-term ROI before making a purchase decision — don’t base it solely on price.
EcoFlow Image
(Source: SolarGis)
Solar Resource and Potential
It’s no secret that sunshine can be in short supply in the UK.
Fortunately, most parts of Britain receive enough visible light from the sun to make residential photovoltaic systems viable — even on rainy days.
But there’s no denying that there are more favourable countries for generating electricity from sunlight.
For example, Australia averages 5-6 hours of peak sun daily, with desert regions getting up to 8 — significantly outshining the UK average of 2-3 peak sun hours a day.
In the context of PV systems, “peak sun hours” refers to the average hours each day the sun shines at the maximum intensity solar panels require to achieve their rated power, the equivalent of 1000W per square meter of photovoltaic material.
When evaluating how much electricity a solar panel array can generate at your location, it’s essential to understand that PV module specifications are determined in a laboratory under ideal conditions.
Standard Test Conditions for Solar Panels
Condition Type Standard Test Condition Real-World Conditions
Solar Incident Angle Always zero, irradiation beam always normal to the PV panel* Variable, and depends on time, date, and site latitude. In the case of rooftop systems, roof orienta
Solar Irradiation Always equal to 1000 Watts/m²* Variable and depends on the time, date, and site latitude. Limited sunshine hours bound system capac
Ambient Temperature Always 25°C* Variable and depends on the time, date, weather condition, and site latitude. Higher ambient tempera
Air Mass Coefficient (AM) Always equal to 1.5* Variable and depends on the time, date, and site latitude. Higher AM with higher latitudes.
System Losses (e.g., Wiring, Inverter) Always Zero* Variable and depends on the design and location of PV panels, inverter, and grid meter.
*Cannot be achieved in real-world operation (Source: ResearchGate)
The testing conditions used by reputable manufacturers of PV modules aren’t replicated exactly in the real world but instead offer an international standard for determining efficiency, rated power, and performance.
Outside the lab, solar irradiation can exceed the benchmark of 1000W/m², in which case solar panels may generate slightly more than their rated power wattage.
However, global horizontal irradiance (GHI) is rarely that intense in the UK, so actual electricity generation is likely to be less than laboratory rated power specs.
For example, a 400W solar panel could generate up to 420W or 430W in extreme sunlight.
In cloudy conditions, the same 400W PV module could produce 300W or less.
Photovoltaic potential by location is forecast primarily using historical GHI data.
But it’s not an exact science.
Fortunately, reputable local solar panel installers will have extensive real-world experience estimating how much electricity your system will generate.
Get a free consultation today.
The Energy Savings Trust offers a free solar panel calculator for estimating photovoltaic potential at your location in the UK.
Electricity Bill Spending
Reducing or eliminating electricity bills is the primary financial benefit of residential solar panel systems.
If you’ve lived in the same home for a year or more, it’s relatively easy to calculate your potential energy bill savings each month.
Simply collect your energy bills for the last 12 months, add up your electricity costs for each month, and divide by 12.
Annual Electricity Costs / 12 = Average Monthly Costs
The higher your electricity bills, the more money you stand to save by reducing consumption from the grid.
Average Electricity Bills by Household Size in the UK (January 2025)
Direct Debit Customers
Electricity usage Average annual consumption Average annual cost* Average monthly cost*
Low (flat or 1-bedroom house / 1-2 people) 1,800 kWh £669.95 £55.83
Medium (3-bedroom house / 2-3 people) 2,900 kWh £943.36 £78.61
High (5-bedroom house / 4-5 people) 4,300 kWh £1,291.34 £107.61
Pay on Receipt Customers
Electricity usage Average annual consumption Average annual cost Average monthly cost
Low (flat or 1-bedroom house/1-2 people) 1,800 kWh £669.95 £55.83
*Based on the January 2025 price cap rates and customers with typical usage, paying by Direct Debit. Rates and standing charges are averages and will vary by region, payment method, and meter type. Rates are effective from 1st January 2025. (Source: British Gas)
Household Size and Usage Patterns
As you can see from the table above, average electricity consumption — and costs — increases with the size of the home and the number of occupants.
Averages can be useful benchmarks, but each household’s electricity consumption and costs vary, largely based on how much power each resident consumes and at what times of day.
Large homes with high electricity costs are likely to benefit most from residential solar power, not least because they’re likely to have more viable surface area for installing solar panels where they’ll receive direct sunlight.
But even if you live in a flat with a balcony, you can benefit from solar power at home.
EcoFlow Image
Electricity Costs
The UK has been in an energy crisis since 2021, with electricity prices peaking at approximately 40-50p per kWh in early 2023.
Energy costs have stabilised somewhat since, with Ofgem’s Energy Price Cap for standard variable and default fixed tariffs set at:
  • 24.68 pence per kWh
  • 60.97p daily standing charge
From January 1st to March 30th, 2025.
The actual price you pay for electricity per kWh depends on numerous factors, including:
1.Unit Rate (per kWh):
  • The price you pay for each kilowatt-hour (kWh) of electricity you consume in pence per kWh (p/kWh).
  • Unit rates can be fixed for the duration of the contract with your energy supplier or variable based on market conditions (typically tied to the Ofgem rate).
2.Standing Charges:
  • Consumers pay fixed daily standing charges — billed in pence per day — to cover the costs of maintaining grid infrastructure, metering, and other expenses.
  • Standing charges remain the same, regardless of how much or how little electricity you consume.
  • Standing charges vary by region and based on other factors, such as payment method and whether you pay single or variable rates for electricity.
3.Electricity Consumption (kWh):
  • The actual amount of electricity you've consumed during the billing period, as measured in kilowatt-hours (kWh), typically has the most significant impact on the cost of your bill.
  • If you have a smart meter, it will automatically send readings to your supplier. If you don't, you will need to provide regular meter readings.
4.VAT (Value Added Tax):
  • VAT is currently set at 5% for home energy bills.
5.Payment Method
  • Direct debit payment plans typically offer a preferential rate.
6.Tariff Type
  • Fixed-Rate Tariffs
  • Variable Rate
  • Prepaid
  • Standard Variable Tariffs (SVTs)
The higher your electricity costs, the higher your potential savings from solar power.
If you feel like you’re paying too much for electricity, Citizen’s Advice offers a free calculator to assess your home electricity costs.
EcoFlow Image
Economy 7 Tariffs, Smart Tariffs, and Time-of-Use Rates
Economy 7 and Smart Tariffs charge different rates for electricity based on various criteria.
Economy 7 is more established, and charges are fixed on-peak and off-peak rates based on the time of day.
Smart Tariffs rely on smart meter technology to offer more dynamic and variable pricing based on factors in addition to or instead of the time of day, such as the level of overall demand on the grid.
In general, time-of-use pricing is designed to encourage electricity consumption when there’s less overall demand on the grid and discourage overconsumption during on-peak hours when demand can exceed supply, potentially leading to blackouts.
If you install a solar panel system with home battery storage, you can save even more money on electricity bills by signing up for an Economy 7 or Smart Tariff energy supplier and only using grid power during off-peak conditions when the rates are lowest.
EcoFlow PowerOcean offers intelligent dynamic monitoring and control to take maximum advantage of favourable time-of-use rates.
Government Solar Incentives
Numerous government grants and schemes designed to encourage rooftop solar panel adoption by consumers and SMEs exist and are currently open to new applicants.
In July 2024, the Labour Government promised “a ‘rooftop revolution’ to encourage builders and homeowners to install solar energy on properties” and established a Solar Taskforce to meet clean energy goals.
The New Homes (Solar Generation) Bill 2024-25 — also known as the Sunshine Bill — proposed compulsory solar panel installations on new-build homes.
However, Parliament recently rejected it at second reading.
It’s highly likely there’ll be new residential solar power incentives announced in the near future.
Take advantage of any grants or schemes you’re eligible for — don’t leave money to help you reach solar payback faster on the table.
UK Government Solar Incentives (Open to Eligible Applicants in 2025)
Solar GrantsRun Dates Eligibility Potential Savings (If Qualified)
Solar Together N/A Homeowners and renters residing in participating council areas 10% - 25%
Energy Company Obligation (EC04)April 2022 – March 2026Homes in England, Scotland, or Wales. Homeowners/residents may be eligible for free solar panels
Home Upgrade Scheme (HUG2)April 2023 to March 2025Low-income, off-grid, and low energy efficiency-rated properties Up to £10,000 (dependent on your local council)
Home Energy Scotland Grant and Loan SchemesClosed for Solar Panel Applications, June 2024 Homes in Scotland Up to £6,000
Welsh Government Warm Homes Nest SchemeN/A Low-income/low-energy performance-rated Welsh homes Homeowners/residents may be eligible for free solar panels
Smart Export Guarantee (SEG)N/A Households with Microgeneration Certification, export meter, and maximum capacity <5MW 1p to +/- 25p per kWh, depending on your choice of SEG licensee and agreement terms
0% VAT on Solar Panel Purchases and Installation April 2022 – March 2027 Purchase and installation of solar panels 0% VAT charged on solar panel purchases. O-5% VAT on installation costs.
Smart Export Guarantee (Feed-In Tariff)
The Smart Export Guarantee (SEG) scheme incentivises owners of renewable energy systems with under 5mW (milliwatts) of output to export low-carbon electricity back to the National Grid.
According to OFGEM, the SEG scheme is for “anyone with an installation of one of the following technology types up to a capacity of 5MW, or up to 50kW for micro-CHP:
● Solar Photovoltaic (Solar PV)
● Wind
● Micro Combined Heat And Power (Micro-CHP)
● Hydro
● Anaerobic Digestion (Ad)
Installations must be located in Great Britain and meet the applicable eligibility criteria.
The SEG scheme requires the participation of three parties:
1.SEG Generators: An individual or business that owns an eligible system and transmits power back to the National Grid.
2.SEG Licenses: Most licensees are mandated to pay SEG Generators for the electricity they transmit to the National Grid, although the terms of a contract between a Generator and Licensee vary dramatically.
It pays to shop around for a Licensee that offers you the best deal for the electricity you export based on the specifics of your system and other factors.
The SEG Licensees from 1 April 2024 to 31 March 2024 are:
Mandatory SEG Licensees
● British Gas Trading Ltd
● E (Gas and Electricity) Ltd
● E.ON Next Energy Ltd
● EDF Energy Customers Ltd
● Electricity Plus Supply Ltd (trading as Utility Warehouse)
● Octopus Energy Ltd (trading as Octopus)
● Octopus Energy Operations Ltd (trading as Octopus)
● Octopus Energy Operations 2 Ltd (trading as Octopus and Shell)
● OVO Electricity Ltd
● Scottish Power Energy Retail Ltd
● SO Energy Trading Ltd
● Utilita Energy Ltd
Voluntary SEG Licensees
● Rebel Energy Supply Ltd
● Pozitive Energy Ltd
3.OFGEM: The Office of Gas and Electricity Markets (OFGEM) is the independent energy regulator for Great Britain, and it regulates — but does not directly administer — the SEG scheme.
It sets out the rules that Licensees and Generators must adhere to, but the SEG scheme is designed to be self-administered by those two parties.
OFGEM will investigate complaints of malpractice by electricity suppliers but is not engaged in the day-to-day management of the relationship between Licensees and Generators.
Most residential solar panel owners receive compensation for the electricity they sell back to the grid as credits against their energy bill.
Grid-connected residential photovoltaic systems without storage rely on grid electricity to power the home at night and when electricity generation falls short of household consumption.
Unfortunately, most SEG Generators pay a significantly higher rate for retail electricity they consume than the Licensee pays per kWh for power sold back to the grid.
Exporting electricity under the SEG scheme can be beneficial but it won’t save you as much money as increasing self-consumption and reducing reliance on the grid.
Learn more about feeding in and how the SEG scheme works here.
EcoFlow Image
Self-Consumption
Government schemes like the Smart Export Guarantee (SEG) are enticing and worth investigating for your specific use case.
However, increasing self-consumption of the electricity your solar panels generate provides a better return on investment over the mid-to-long term.
The best way to dramatically increase the self-consumption of solar power is to install home battery storage.
Even if you already participate in the SEG with a photovoltaic system, it’s not too late to retrofit high-performance solar batteries with your existing components.
EcoFlow PowerOcean DC Fit retrofits industry-leading LFP battery storage in increments of 5kWh per home battery, up to a maximum of 15kWh.
Most PV systems don’t require additional components or re-permitting for remaining on-grid.
Energy-efficient home improvements can also increase self-consumption by limiting how much electricity you lose — particularly in older houses and flats.
EcoFlow Image
How Do You Calculate Payback on Solar Panels?
Here’s the simplified step-by-step formula for estimating your solar payback period.
1.Calculate the Total System Cost
Add up all the costs involved with purchasing and installing your system, including:
  • Solar Panel or Other Photovoltaic Modules
  • Balance of System
  • Installation
  • Mounting Hardware
  • Finance and interest charges
  • Miscellaneous Expenses
2.Estimate Annual Electricity Savings
  • Estimate annual electricity generation
  • Calculate self-consumption
  • Estimate annual electricity bill savings: Multiply expected electricity generation for self-consumption by the current retail price per kWh. Don’t forget to include standing charges.
Using the above steps, you can estimate how much money you’ll save on annual electricity bills
3.Estimate Smart Export Guarantee (SEG) Income (If Applicable)
  • Estimate Annual Electricity Sold Back to the National Grid (in kWh)
  • Determine SEG Income under the terms of the contract with your SEG Licensee
4.Calculate Total Annual Savings
  • Add annual savings (Step 2) and SEG Income (Step 3)
The combined total reflects your annual savings.
5.Calculate the Payback Period
Divide the Total System Cost (Step 1) by the Total Annual Savings (Step 4).
Formula: Payback Period (Years) = Total System Cost / Total Annual Savings
For example:
  • Step 1: Total System Cost = £8,000
  • Step 2: Annual Electricity Savings = £1,000
  • Step 3: Annual Export Income = £300
  • Step 4: Total Annual Savings = £1,000 + £300 = £1,300
  • Step 5: Payback Period = £8,000 / £1,300 = 6 years
The estimated solar payback period using this example is just over 6 years.
Are Solar Panels a Long-Term Investment?
Photovoltaic systems that generate electricity from solar energy are considered a viable mid-to-long-term investment in the UK.
Annual return on investment (ROI) estimates for home solar panel installations range from 5% to 12% per year over the lifetime of the system.
Upfront purchase and installation costs can be significant, but there are many options available to minimise your initial investment and achieve a substantial return, including:
  • Government solar grants and other incentives
  • Feeding into the National Grid via the Smart Export Guarantee scheme
  • Low-to-no interest financing from direct-to-consumer manufacturers
  • Increased property value
  • Limited exposure to rising electricity prices
EcoFlow Image
  • How Long Does It Take To Break Even on Solar Panels?
    Most home solar panel systems in the UK reach the breakeven point in 10 years or less. The time it takes to recoup your initial purchase and installation costs is often referred to as the solar payback period. Many factors go into estimating your individual payback period and return on investment, including location, system type, electricity consumption, and energy bill savings.
  • How Soon Do Solar Panels Pay for Themselves in the UK?
    Most residential solar panel systems in the UK achieve solar payback in 6-10 years. The solar payback period is the time it takes to recoup your initial purchase and installation costs on PV modules and system components like solar inverters and battery storage. Multiple factors must be considered to estimate your payback period and ROI, including location, system type, electricity consumption, and energy bill savings.
  • How Many Years Does It Take To Get Your Money Back on Solar Panels?
    Six to 10 years is the average time it takes to recoup purchase and installation costs for a home solar panel system in the UK. The annual return on investment (Solar ROI) averages 6-12% over the lifetime of the system. High-quality solar panels last 25 to 30 years before needing be replaced, longer than many home roofs.
For most homeowners in the UK, purchasing and installing a residential solar panel system is a solid investment.
The less electricity you consume from the National Grid, the bigger your energy bill savings and the shorter the solar payback period.
The best way to maximise your solar ROI is to increase self-consumption.
EcoFlow’s PowerOcean home solar battery + solar panel solutions reduce — or eliminate — electricity consumption from the grid to maximise energy security and self-consumption.
Schedule your free consultation today.
EcoFlow offers innovative home battery storage solutions for homeowners seeking to optimize electricity consumption, cut costs, and achieve independence from the National Grid. Since 2017, EcoFlow’s home battery storage and solar generator solutions have been trusted by households in over 85 countries worldwide. EcoFlow's industry-leading home battery technology is designed to efficiently store electricity generated from solar energy and other sources to attain energy security and eliminate peak billing tariffs.
