Choose your country or region
Heat Pump Repair and Servicing: A Complete Troubleshooting Guide (2026)
Is your heat pump acting up just when you need it most? Getting a timely heat pump repair is essential for maintaining home comfort. With this guide, learn the problems that you can safely handle yourself and when it’s time to call for professional help to ensure continued system efficiency.
Why Routine Heat Pump Servicing Matters
Regular maintenance and timely heat pump repairs are essential to keep your air source heat pump (ASHP) running efficiently. Understanding how does a heat pump work step-by-step can help you identify which components need the most attention during regular maintenance and checks. It is also one of the most effective ways to save electricity at home.
UK households often see a significant reduction in winter bills through proper system calibration, especially with systems like EcoFlow PowerHeat, which are designed for optimal year-round performance.
Even minor problems, such as clogged filters or low refrigerant levels, can reduce efficiency (SCOP), leading to increased energy consumption or long-term damage. Not all homeowners are aware that ignoring these signs can shorten a system’s lifespan.
Staying on top of routine care and addressing problems early protects your investment, keeps your home comfortable, and reduces your carbon footprint—especially when paired with a solar battery setup, allowing you to run your heat pump on stored renewable energy. A well-maintained heat pump is quieter, greener and more cost-effective to operate.
For those pursuing a more independent off grid lifestyle, this level of maintenance is the foundation of energy reliability.
Heat Pump Repairs: Common Symptoms Homeowners Notice
If your heat pump system is experiencing any of these symptoms, you might have to look for a heat pump repair service near you:
  • No heat or lukewarm radiators:The system might have a poor ability to reach the set temperatures during colder months.
  • Short cycling or constant running:This is usually an indication of a defect in the thermostat, sensors or refrigerant amount.
  • Outdoor unit iced up:Some frost is normal, but heavy ice build-up could mean the defrost cycle isn’t working properly.
  • High electricity bills:A sudden spike may indicate that your heat pump is working harder than it should.
  • Unusual noises or vibrations:Rattling, humming, or buzzing could mean loose parts or wear and tear.
  • Error codes on the controller:These provide helpful clues about what’s going wrong.
5 DIY Checks Before Booking a Heat Pump Repair Service
Before booking heat pump repair servicing, there are simple checks you can safely try at home. These quick steps can fix the problem or assist the repair engineer in diagnosing it faster.
  1. Double-check thermostat setting and mode: Make sure that your system has been adjusted to heating and the temperature level is high enough to activate the heat pump.
  2. Inspect beakers and isolation switches Check your main fuse box to ensure the circuit hasn't tripped. Also verify that the external isolation switch has not been turned off. A simple reset can often bring the system back online.:
  3. Clean filters and outdoor unit:Dirty filters slow down the flow of air, and leaves or snow surrounding the outdoor unit may prevent its operation. A quick tidy-up helps.
  4. Review heating curve and DHW schedule:Doing these is crucial especially if outdoor temperatures have recently dropped.EcoFlow PowerInsight helps monitor your heat pump system performance, making it easier to catch issues early and share data with your engineer.
  5. Bleed radiators or ground loops:Air in the system can reduce heat output. Bleeding radiators is a simple DIY job with big results
These easy checks might save you a call or make your heat pump repair visit quicker and more effective.
When to Call a Professional for Heat Pump Servicing
Some heat pump issues are best left to the experts. While basic checks can solve minor problems, certain heat pump system malfunctions need professional attention to ensure safe and effective heat pump repair.
In case of the following, then you should call in a qualified engineer:
  • Constant icing or defrost safety cycle failure: In case your outdoor unit is continuously icing over and is not properly defrosting, it might be a sensor or control issue.
  • Leaks or pressure defects of refrigerants:It involves an F-gas certified technician, and it may affect the effectiveness and safety.
  • Repeated fault codes or sensor failures: When the error persists, then there is a problem in the system that requires diagnostic tools.
  • Persistent undercycle or under-performance: This may be due to a system design issue or sizing problem, and an expert examination is required.
If these errors occur during a cold snap, you may need to seek emergency air source heat pump repair to restore heating quickly. Before authorizing major work, always check your UK warranty status, as many component failures may be covered under your original purchase agreement.
Frequent Root Causes of Heat Pump Issues
The symptoms vary, but problems may stem from these root causes:
  • Airflow limitation: Blocked airflow from leaves, snow, or fencing around the outdoor unit can lower efficiency and cause faults.
  • Wrong heating curve or flow temperature: Turning on the wrong setting can lead to lukewarm radiators or high bills. Utilizing a smart energy management system for homes can help you monitor these curves in real-time to avoid efficiency drops.
  • Undersized radiators or poor hydronic balancing: Radiators that are unable to produce low flow temperatures can lead to cold rooms and overwork the system.
  • Air or sludge in the system: Dirty water or trapped air will cause cold spots as well as noise and permanent damage unless filtered or treated.
  • Pipework insulation or incompatible emitters: Heat loss through pipes or using the wrong type of emitters reduces system efficiency.
Sound familiar? Perhaps it is high time to schedule a professional heat pump repair and system check-up. Having a clear plan for what to do if heat pump stops working can save you significant time and prevent further damage to the unit.
ecoflow powerinsight
Understanding Icing and Defrost Cycles
During colder months, a small amount of frost forming on heat pumps is normal. These systems are designed to defrost automatically and proceed to operate effectively.
But when you observe thick ice build-up that does not melt, something may be wrong. Common causes include blocked airflow, faulty sensors, and defrost cycle failures.
As a homeowner, you can help by clearing leaves, snow, or debris from around the unit. If icing continues, it’s time to call a professional to check sensors, refrigerant levels, and system controls as part of a proper heat pump repair.
What’s Included in a Professional Heat Pump Servicing
A professional heat pump repair service covers a full health check-up for your system. Done annually, it helps keep your heat pump running efficiently, safely, and for as long as possible.
Here’s what a typical service includes:
  • Electrical safety checks: All wiring and connections are tested to ensure safe, reliable operation. Maintaining these electrical connections is equally critical for homeowners with a whole house battery backup for a stable energy circuit.
  • Coil and filter cleaning: Dirty filters and coils reduce efficiency, so these are thoroughly cleaned or replaced.
  • Pump and fan inspections: Moving parts are checked for wear, noise or signs of failure.
  • Refrigerant pressure and leak testing: Low refrigerant can cause performance issues; leaks are identified and fixed by F-gas certified engineers.
  • Ground source systems: Antifreeze levels and loop pressure are tested to ensure stable operation in colder conditions.
Regular servicing not only reduces the risk of costly heat pump repairs but also helps keep your system efficient and eco-friendly. Investing in high-quality heat pump repair solutions ensures that any replaced components meet the original manufacturer's efficiency standards.
FREE CONSULTATION
Home Energy Storage System (e.g. OCEAEN 2)
I'm not sure / Just exploring
Preventing Future Heat Pump Repairs
Preventing future heat pump repairs starts with good habits and regular care. Taking simple steps now can save you time, money and stress later on.
Take note of the following to keep your system running smoothly:
  1. Schedule annual servicing: A professional check helps catch small issues before they become big problems.
  2. Keep the outdoor unit clear: Remove leaves, snow, or debris to ensure proper airflow and prevent icing.
  3. Optimise the heating curve: Avoid running your heat pump like a traditional boiler to maintain efficiency and comfort.
  4. Monitor performance: Using heat and electric metres helps track your system’s SPF, letting you spot problems early.
  5. Log errors and services: Keeping a simple record ensures consistency and helps engineers diagnose issues faster.
Pairing your heat pump with EcoFlow PowerGlow, a smart immersion heater, can further boost efficiency, giving your home reliable warmth while reducing energy consumption and wear on your system.
Observe Regular Servicing for Your Heat Pump Systems
Regular servicing keeps your heat pump running smoothly, efficiently, and safely. While many minor issues, like blocked filters or incorrect settings, can be solved with simple at-home checks, some problems run deeper.
If your system shows signs of persistent faults, unusual noise, or reduced performance, it is best to call a qualified technician. Issues involving refrigerant or electrical components should always be handled by professionals to avoid further damage or safety risks. For EcoFlow maintenance, you can get a consultation service to check your overall heating system as well.
Routine service appointments catch small problems early, extend the life of your overall home energy ecosystem, and ensure it continues to run at peak efficiency, saving you stress, energy, and money in the long term. At a time when many ask why are energy prices so high, maintaining your heat pump's efficiency is more important than ever.
1. How often should I service my heat pump?
Heat pumps are generally easy to maintain. It’s best to book a heat pump repair service once or twice a year. Regular checks keep it running efficiently, help spot small issues early and reduce the risk of unexpected breakdowns in colder months.
2. What is the most common problem with heat pumps?
Heat pumps not turning on is one of the top common issues. If your heat pump does not run, check the thermostat settings, circuit breaker and air filter first. If it still won’t start, call a professional to avoid further damage or safety risks.
3. Can I fix my heat pump myself?
You can try simple checks like clearing debris, cleaning filters, or checking your settings. However, for anything involving refrigerant, electrical parts or error codes, it’s safest to contact an authorized EcoFlow service center or a qualified repair technician.
4. Why is my heat pump running constantly?
This may point to thermostat issues, sensor faults or low refrigerant. If simple setting checks do not help, book a professional inspection.
5. Is frost on my heat pump normal?
Yes, a light frost is normal in winter. But thick ice that does not clear after a defrost cycle may mean blocked airflow or a system fault.
Home Energy Management
