Choose your country or region
Dryer Electricity: How Much Does a Dryer Cost to Run and How to Save
When the weather turns damp and the washing line stays empty, the tumble dryer can quickly become part of the weekly routine. It can also add a noticeable amount to a UK electricity bill, especially if you have an older vented or condenser model. Knowing how much each load uses and which everyday habits make a difference can help you keep laundry costs in check through the colder months.
Key Takeaways
  • Dryer type decides how much power you burn: A typical full cycle can use around 4.5–5.3 kWh for a vented or condenser dryer, compared with approximately 1.4–2.2 kWh for some heat pump models.
  • The costs quietly stack up: At Ofgem’s Q4 2026 rate of 26.32p/kWh, two loads a week runs you £123–£145 a year on a vented or condenser dryer — but just £38–£60 on a heat pump model.
  • Small habits make a difference: Use the highest suitable spin speed on your washing machine to remove more moisture before drying, and clean the lint filter after every load to maintain efficient airflow.
  • Get the timing right and the grid bill drops: Take advantage of cheaper Economy 7 periods when you can safely supervise the appliance, or use solar electricity stored in a home battery.
How Much Electricity Does a Tumble Dryer Use in the UK?
The amount of electricity a dryer uses depends mostly on its design, the load and the programme. It helps to start with a typical cycle, then compare how the main dryer types use energy.
Average Electricity Consumption per Drying Cycle
Most full-load drying cycles in a typical 8 kg or 9 kg domestic machine consume between 1.4 kWh and 5.3 kWh of electricity, depending on the dryer type and model. A half load does not necessarily use half the electricity of a full load. For example, a Hotpoint vented dryer uses 2.64 kWh for a half load, compared with 4.99 kWh for a full load. Drying dense cotton towels or heavy bedding can also require more energy than lighter loads, depending on the programme and moisture content.
Electricity Consumption by Tumble Dryer Type
Three main tumble dryer designs sit in UK kitchens and utility rooms, each handling heat and moisture differently:
  • Vented tumble dryers expel warm, damp air outside through a flexible hose. Because all that heated air goes straight out the wall, they typically consume 4.5 to 5.3 kWh per full cycle.
  • Condenser tumble dryers cool the moist air internally and collect water in a removable tank, making them easier to place in flats or internal utility cupboards. Energy usage remains high, however, sitting around 4.5 to 5.2 kWh per full load.
  • Heat pump tumble dryers operate on a closed-loop heat-exchange system, reheating and reusing warm air at lower drum temperatures. That efficiency cuts electricity demand roughly in half to 1.4 to 2.2 kWh per full cycle.
Tumble Dryer TypeTypical Power RatingElectricity per Full Cycle (8–9 kg)Annual Usage (2 Cycles/Week)
Vented Dryer2,500 – 3,000 W4.5 – 5.3 kWh468 – 551 kWh
Condenser Dryer2,500 – 2,800 W4.5 – 5.2 kWh468 – 541 kWh
Heat Pump Dryer600 – 850 W1.4 – 2.2 kWh146 – 229 kWh
How Much Does It Cost to Run a Tumble Dryer?
Once you know a cycle’s energy use, you can estimate its cost using your electricity unit rate. The examples below use Ofgem’s price cap rate for the final quarter of 2026; your own tariff may be different.
Average Cost per Drying Cycle
Using Ofgem’s average price cap rate of 26.32p per kWh for customers on standard variable tariffs paying by Direct Debit in England, Scotland and Wales (1 October to 31 December 2026), a single full drying cycle works out as follows:
  • Vented dryer (4.8 kWh): ~£1.26 per cycle
  • Condenser dryer (4.6 kWh): ~£1.21 per cycle
  • Heat pump dryer (2.1 kWh): ~£0.55 per cycle
Monthly and Annual Tumble Dryer Running Costs
For a household running two full loads a week (104 cycles a year), the table uses 104 ÷ 12 cycles for the average monthly cost. Larger families doing four loads a week over muddy winter football seasons can easily double these figures. For homes with solar panels, solar battery storage can change how much of that electricity needs to come from the grid.
Dryer TypeCost per Cycle (at 26.32p/kWh)Average Monthly CostAnnual Cost (104 Cycles)
Vented Dryer£1.18 – £1.39£10.26 – £12.09£123.18 – £145.08
Condenser Dryer£1.18 – £1.37£10.26 – £11.86£123.18 – £142.34
Heat Pump Dryer£0.37 – £0.58£3.19 – £5.02£38.32 – £60.22
How to Calculate Tumble Dryer Running Costs
Estimating your own machine’s cost takes three steps using your energy bill and the appliance’s rating plate or smart plug reading:
  1. Find the cycle kWh figure: For newer labels showing kWh per 100 cycles, divide by 100. For older labels showing annual consumption based on 160 cycles, divide by 160. These are standardised estimates; actual usage varies by programme and load. If you’re tracking total household electricity use, our guide on how to read a smart meter explains where to find the kWh reading.
  2. Check your electricity unit rate: Look at your supplier’s app or latest statement for your pence-per-kWh rate.
  3. Multiply kWh by unit rate: For example, a 2.16 kWh cycle multiplied by £0.2632 equals £0.57 per load.
EcoFlow PowerInsight 2 Home Energy Monitor
What Factors Affect Tumble Dryer Running Costs?
A dryer can use more electricity than you expect, even if you run it the same number of times each week. A full drum, a clogged filter or a programme that keeps running after the clothes are dry can all add time to a cycle.
Energy Efficiency and Dryer Condition
The rescaled A to G energy label is due to become mandatory in Great Britain on 19 January 2027, following a transition period. Compare the energy figures for the models you are considering. Worn door seals or blocked vents can also reduce efficiency and lengthen drying times.
Load Size and Drum Capacity
Stuffing a 9 kg drum to the brim blocks hot air from tumbling between garments, leaving damp pockets in the middle and forcing extended cycles. Conversely, drying three work shirts on their own wastes energy heating empty drum space. Filling the drum roughly two-thirds to three-quarters full leaves enough airflow room for rapid moisture evaporation.
Drying Programmes and Temperature Settings
High-heat cotton programmes hit peak wattage for longer stretches. Sensor-dry settings, which monitor residual humidity inside the drum and shut off automatically once clothes reach “cupboard dry” or “iron dry”, prevent the heater from running needlessly after laundry is already dry.
Spin Speed and Remaining Moisture in Clothes
Mechanical spinning in a washing machine extracts water far more cheaply than thermal evaporation inside a dryer. Clothes spun at 800 rpm retain significantly more water than garments spun at 1,400 or 1,600 rpm, which can lengthen the drying cycle. To estimate the cost of both steps, see how much electricity does a washing machine use for wash-cycle energy figures.
Frequency of Tumble Dryer Use
Tumble dryer use in British households varies significantly by season. A UK government survey found that households with tumble dryers used them a median of three times a week in winter, compared with zero times in summer. This seasonal pattern reflects the greater reliance on indoor drying when outdoor conditions are less favourable.
Electricity Tariffs and Time of Use
Standard variable tariffs charge the same unit rate around the clock, whereas multi-rate tariffs such as Economy 7, Economy 10, or smart EV tariffs offer substantially cheaper overnight electricity. For households on Economy 7 or other time-of-use tariffs, simply knowing a dryer’s single-cycle kWh consumption is only half the picture—understanding whole-home load timing and energy flows matters just as much. Tools like the EcoFlow PowerInsight 2 home energy monitor allow families to view whole-house electricity consumption, solar generation, and battery charge/discharge status on a single display. Having clear visibility into household energy patterns makes it far easier to schedule laundry, drying, and other high-draw appliances around cheaper off-peak tariff windows.
EcoFlow OCEAN 2 Plus single phase home battery
How Can You Reduce Tumble Dryer Electricity Costs?
You don’t have to stop using the dryer to bring its costs down. A few changes before and after each cycle, along with smarter timing, can make a difference. For homes that already generate solar power, the EcoFlow home energy ecosystem shows how compatible monitoring, storage and controls work together.
Use a Higher Spin Speed Before Drying
Running a high-speed spin cycle on your washing machine, typically 1,400 rpm or higher for cottons and towels, uses only a fraction of a kilowatt-hour while removing substantial water before clothes ever enter the dryer. Keep delicate woollens or synthetics on lower spin speeds to avoid fabric damage, and shake out tangled bedsheets before loading the dryer so they do not ball up.
Choose Eco Programmes and Avoid Overdrying
Eco cycles run slightly longer at lower heater temperatures, cutting overall kWh draw compared with rapid or extra-dry presets. Selecting “iron dry” for shirts or bedlinen leaves a tiny hint of moisture that evaporates within minutes on a hanger, saving the final energy-heavy stage of a full cupboard-dry cycle.
Clean the Lint Filter and Heat Exchanger Regularly
Fluff trapped in the door filter restricts airflow across the heating element and sensors. Clearing the lint screen after every single load takes ten seconds and keeps airflow unobstructed. On condenser and heat pump dryers, rinsing the lower heat exchanger or secondary sponge filter every month prevents efficiency drops that quietly inflate running times.
Use Solar Energy and Battery Storage to Reduce Grid Electricity Costs
For households looking to cut grid electricity use from high-draw appliances even further, pairing rooftop solar with home battery storage offers a practical route. During daylight hours, solar panels power daytime household loads and store surplus generation rather than exporting it for a modest feed-in rate, keeping stored electricity available for evening laundry runs or overcast days. Systems like the EcoFlow OCEAN 2 Plus Single-Phase integrate solar generation, modular LiFePO₄ battery storage and smart energy management in a single IP66-rated setup. That flexibility lets households run energy-intensive appliances like tumble dryers on self-generated solar power or off-peak stored energy rather than paying peak grid unit rates.
FREE CONSULTATION
Home Energy Storage System (e.g. OCEAEN 2)
I'm not sure / Just exploring
Tumble drying can cost more in winter, when wet weather sends more laundry indoors and loads of towels and bedding take longer to dry. But the cost depends on your dryer and how often you use it: at the Q4 2026 price cap rate, a heat pump model can cost less than half as much per cycle as a vented or condenser dryer. Faster washing machine spins, a clean filter and careful timing can help bring the bill down further, so you can keep clothes dry without running the machine longer than needed.
Is It Worth Buying a Heat Pump Tumble Dryer?
A heat pump model can cost less to run. To estimate the payback period, divide the extra purchase cost by your expected annual electricity savings. Because it recycles warm air at lower temperatures, it uses roughly half the electricity of a vented or condenser unit while being gentler on clothes.
Does a Tumble Dryer Use More Electricity in Winter?
Yes, tumble dryers generally draw slightly more electricity in winter, especially if installed in an unheated garage, utility room, or conservatory. Cold ambient air means the machine works harder to warm the drum and air intake, while heavier winter fabrics like jeans, fleeces, and thick towels hold more water and take longer to dry.
What Size Home Battery Do You Need to Run a Tumble Dryer?
Check that the battery has enough usable energy for the drying cycle and other loads, and that the inverter’s continuous output can handle their combined power demand. A heat pump dryer needs roughly 1.4 to 2.2 kWh per full cycle, whereas a vented or condenser model requires around 4.5 to 5.3 kWh, so matching battery capacity to your dryer type ensures you do not drain the pack before evening peak hours end.
Does Leaving a Tumble Dryer Plugged In Use Electricity?
A modern tumble dryer may use a small amount of electricity in standby mode, depending on its display and network features. Under UK ecodesign rules introduced in April 2026, standby power limits range from 0.5 W to 2 W for different operating modes. If left in these modes continuously, this equates to approximately 4–18 kWh a year, costing around £1–£4.60 at 26.32p/kWh. Switching the appliance off at the socket can eliminate standby consumption.
How Many Solar Panels Does It Take to Run a Dryer?
The number of panels depends on solar output and the dryer’s power demand. Some heat pump dryers require around 800–1,000 W, while conventional condenser models can require considerably more. Solar panels can help power a dryer during sunny periods, while a home battery stores surplus electricity for use when solar output is low.
Efficiency Tips
