Choose your country or region
Is the Boiler Upgrade Scheme Still Running in 2026? What UK Homeowners Need to Know
As we march toward the UK's ambitious Net Zero targets, the landscape of home heating is shifting faster than a British weather forecast. If you’ve been wondering whether the government is still helping out with the eye-watering costs of ditching your old gas guzzler, the answer is a resounding yes.
In 2026, the Boiler Upgrade Scheme (BUS) remains the cornerstone of residential decarbonisation. This guide breaks down exactly what the scheme looks like today, how much cash you can actually get back, and how to pair the grant with modern tech to ensure your energy bills don't skyrocket while you’re trying to do your bit for the planet.
What the Boiler Upgrade Scheme Covers in 2026
The scheme has evolved quite a bit since its inception. It’s no longer just a "nice to have" pilot program; it's a streamlined machine focused on getting fossil fuels out of our semi-detached dreams.
1. Understanding Eligible Boiler Types
While the name says "Boiler," the scheme is strictly for low-carbon heating. You won't get a penny for a new gas or oil boiler. The focus is firmly on Air Source Heat Pumps (ASHPs), Ground Source Heat Pumps, and, in very specific rural cases, biomass boilers.
2. Who Can Apply and Property Requirements
Most homeowners in England and Wales are eligible, provided they own the property (including second homes and buy-to-lets). However, newly built homes are usually excluded from the Boiler Upgrade Scheme, as they are often already designed to high energy efficiency standards. The big catch? Your home must have a valid Energy Performance Certificate (EPC) with no outstanding recommendations for loft or cavity wall insulation. You’ve got to wrap the house before you heat it!
3. How the Scheme Supports Net Zero Targets
By incentivising the switch from gas to electricity, the government aims to slash the 15% of UK carbon emissions that come from home heating. In 2026, the electricity grid is greener than ever, making every kilowatt-hour used by a heat pump significantly cleaner than burning gas.
4. Key Changes from Previous Years
The most notable shift in 2026 is the stricter efficiency mandates. To qualify for the grant in 2026, heat pump systems must meet higher Seasonal Coefficient of Performance (SCOP) ratings—typically SCOP ≥ 3.8. SCOP measures the efficiency of a heat pump over an entire heating season; the higher the number, the more heat you get per unit of electricity consumed, ensuring your home stays warm without excessive energy bills.
How Much Can Homeowners Save with the Scheme?
Let’s talk numbers. Nobody switches a boiler just for the vibes; the financial "maths" has to stack up.
1. Typical Grant Amounts Available in 2026
The grant currently sits at a substantial £7,500 for air source heat pumps. This "voucher" is usually applied for by your installer and taken right off the quote, so you aren't waiting months for a cheque to clear.
2. Estimated Energy Bill Reductions
While heat pumps use electricity (which is pricier per unit than gas), their incredible efficiency means you can see a reduction in "thermal" costs. If you’re moving from an old G-rated boiler, the savings are palpable from day one.
3. Calculating Payback Period Including the Grant
With the £7,500 leg-up, the "payback period"—the time it takes for energy savings to cover the initial install cost—has dropped significantly. For many UK homes, this window is now comfortably under 8 to 10 years.
4. Carbon Footprint Reduction and Efficiency Gains
A typical UK home can reduce its carbon footprint by over 2 tonnes of CO₂ per year when switching from an old G-rated gas boiler to an air source heat pump, according to BEIS Energy and Emissions Statistics 2025. This is roughly equivalent to driving a petrol car halfway around the world.
EcoFlow PowerOcean home battery storage system
How to Apply for the Boiler Upgrade Scheme
The process has been simplified over the years to remove the "red tape" headaches homeowners used to dread.
1. Step-by-Step Application Process
  1. Find an MCS-certified installer: They are the only ones who can trigger the grant.
  2. Get a quote: Your installer will advise if your home is "heat pump ready."
  3. Installer applies: They lead the application on the Ofgem portal.
  4. Voucher confirmation: You’ll receive an email to confirm you’ve instructed the work.
2. Required Documents and Checks
You’ll need your property title deeds (usually checked via Land Registry) and that all-important EPC. If your EPC says you need insulation, you’ll need to get that sorted before the voucher is issued.
3. Tracking Your Application Status
Most installers now use digital dashboards where you can see the status of your voucher. Once the installation is finished, the installer redeems the voucher, and the government pays them directly.
How to Maximise Value from the Scheme
Getting the grant is just the start. To truly win at the home energy game in 2026, you need to think about how that heat is managed and powered through a smart home energy management system.
1. Choosing the Right Heat Pump for Your Home
To maximise your Boiler Upgrade Scheme grant in 2026, selecting a heat pump that matches your home’s heat demand is essential. Under the current framework, ASHPs remain the gold standard. However, larger, older British homes often struggle to maintain high temperatures efficiently.
This is where the EcoFlow PowerHeat Air Source Heat Pump stands out. Using R290, a natural refrigerant, it delivers a powerful 20kW output—well suited to drafty Victorian terraces or larger detached properties where undersized systems increase running costs. Unlike basic models, it offers Advanced Zone-by-zone Control. Instead of heating unused rooms to 21°C, you can focus warmth where it’s needed, allowing you to micro-manage your comfort and your wallet.
2. Maximise Savings Using Renewable Energy and Storage
A heat pump is only as cheap as the electricity it consumes. Since heat pumps often ramp up in the evening when UK grid prices spike, "raw" running costs can be a bit of a shock.
The secret to 2026 energy independence is the EcoFlow PowerOcean (Single-Phase). It’s a home battery system tailored for UK houses with up to 45kWh of capacity. By storing solar energy during the day or topping up on cheap "off-peak" luxury rates overnight, you can power your heat pump during the expensive evening peak. It essentially lets you "time-shift" your energy, making the most of your BUS-funded heat pump without the high-noon electricity bills.
3. Regular Maintenance for Long-Term Benefits
Don't just fit and forget. Annual servicing of your heat pump ensures it maintains its efficiency rating, which is vital for keeping your manufacturer's warranty—and your low bills—intact.
EcoFlow PowerHeat heat pump with solar power
Common Application Mistakes to Avoid
While the application process is designed to be installer-led, several "hidden" administrative hurdles can still derail your grant. Being aware of these common pitfalls ensures your £7,500 voucher moves smoothly from reservation to redemption.
1. Misunderstanding Property Eligibility
Only existing homes and "self-builds" (completed within the last 12 months) qualify. Standard developer-led new builds are strictly excluded, as they must meet separate building regulations for low-carbon heating.
2. The Paperwork Identity Trap
Ofgem requires an exact name match across your Council Tax bill, Energy bill, and Land Registry. Ensure your details are updated and consistent before the application is submitted to avoid automated rejections.
3. Ignoring Regional Jurisdictions
The BUS only covers England and Wales. If you are in Scotland, you must use the Home Energy Scotland scheme; in Northern Ireland, look for local Alternative Fuel Payments to avoid missing your regional funding window.
4. Jumping the Gun on Installation:
Never start physical installation until your installer confirms the voucher is officially "reserved." The grant is not retrospective—if the heat pump is installed before approval, you lose the £7,500 and must pay the full cost.
5. EPC Validity and Insulation
While the "insulation-first" mandate has relaxed, a valid EPC (issued within the last 10 years) is still mandatory to ensure you make your home more energy-efficient before upgrading the heating system. Without a current certificate on file, the application portal will automatically stall your request.
FREE CONSULTATION
Home Energy Storage System (e.g. OCEAEN 2)
I'm not sure / Just exploring
The Boiler Upgrade Scheme in 2026 is a massive opportunity to future-proof your home, creating a foundation that works perfectly alongside home battery storage for total energy control. By combining a £7,500 grant with high-performance tech like the EcoFlow PowerHeat and securing your energy supply with the PowerOcean battery, you aren't just swapping a boiler—you're building a smart, self-sufficient energy ecosystem.
1. Is the boiler upgrade scheme means tested?
No, the Boiler Upgrade Scheme is not means-tested. It is available to all eligible homeowners in England and Wales, regardless of income, provided the property meets the energy efficiency requirements.
2. How long will the boiler upgrade scheme last?
The scheme is currently scheduled to run until 2028. However, funding is allocated in "pots," so it is always best to apply sooner rather than later to ensure a voucher is available for your project.
3. Can old people get a grant for a new boiler?
Pensioners are eligible for the BUS grant just like any other homeowner. If you are looking for a standard gas boiler replacement, you might want to check the "ECO4" scheme instead, which focuses on low-income and vulnerable households.
4. How much is the boiler upgrade scheme grant?
The grant is £7,500 for Air Source Heat Pumps. This was increased from £5,000 in late 2023 to help bridge the price gap between gas boilers and sustainable alternatives.
5. How to tell if a boiler needs replacing?
If your boiler is over 10-15 years old, is making banging noises, or your bills are rising despite similar usage, it’s likely time. A yellow flame instead of a blue one is also a major red flag that requires immediate attention.
Home Heating System
