Can You Combine the UK's Solar Electricity Grant With Home Storage Solutions?
Solar electricity grant programmes are helping UK homeowners cut the cost of installing solar panels, but many do not realise they can also fund or pair a home battery alongside them. Whether you are eligible for ECO4, the Warm Homes plan, or another solar power grant, adding a battery to your setup can significantly increase how much of your generated electricity you actually use.
What the UK’s Solar Electricity Grant Actually Means
There is not just one solar electricity grant that homeowners can apply for. In the UK, there are four main programmes for households that wish to switch to PV systems. These programmes are the ECO4 (Energy Company Obligation), Home Upgrade Grant (HUG), Warm Homes (England and Wales variants), and Home Energy Scotland (plus local authority grants).
These solar power grants have their own targets.
ECO4 is available to low-income households and grants 100% financial coverage for solar panel installation.
The Warm Homes programme caters to low-income families or tenants, and can provide up to £30,000.
The Home Energy Scotland programme offers a loan of up to £5,000 for eligible households.
The Home Upgrade Grant provides monetary support for low-income, off-the-grid homes.
Some of these schemes cover battery top-ups or storage add-ons, while others only cover solar panel installation.
How These Solar Power Grants Interact With the Smart Export Guarantee
The Smart Export Guarantee (SEG) is one of the most widely used solar power grants for homeowners in the UK. The SEG is an ongoing payment for exported electricity, which is separate from installation grants. This programme even includes panels and solar energy storage. You can apply for the SEG if you’re a solar power system owner. It also does not disqualify you if you have existing grants.
The requirement for SEG eligibility includes an MCS-certified installation, a smart meter, and an eligible supplier. The SEG incentivises exporting excess energy into the grid, but using a battery avoids exports and lets you use the stored energy later, leading to long-term savings.
When Battery Storage Grants Are Available
Pairing a home storage battery like EcoFlow PowerOcean with your solar system lets you store surplus generated energy for use later. Battery units require a significant upfront investment, but several solar electricity grant programmes can help cover the cost.
The Home Upgrade Grant can include battery storage when the installation improves your solar system's performance. For Scottish homeowners, the Home Energy Scotland programme has previously offered combined solar and battery storage packages. Some local authority climate programmes also provide partial battery storage grants to encourage self-consumption.
Combining Solar Panels and Battery Storage — How It Works in Practice
Scenario 1: Grant-Funded Solar Panels Only
With solar panels, you can make use of solar energy to generate electricity to power your home. This increases self-consumption by 30% to 40% without the use of a storage battery.
Through the use of energy supplier-approved meters and certified inverters, you can now export excess energy into the grid and get paid for it. However, long-term savings are limited by daytime-only usage patterns.
Scenario 2: Solar Panels With Home Battery
A battery storage system lets you capture the free solar energy your panels generate and use it later — during the evening or at peak grid hours. This raises self-consumption to 70–80% and leads to greater long-term savings. Even if your solar power grant only covers the panels, adding a battery extends the financial benefit considerably.
Quick Comparison
| System Setup | Self-consumption | Typical Savings | SEG income | Overall Bill Reduction |
| Solar panels only | 30–40% | Moderate | Moderate | Medium |
| Solar + battery | 70–80% | Higher | Lower (less export) | Greater overall savings |
Solar Power Grants for Homeowners: Eligibility and Technical Requirements
When applying for grants, one key requirement is using MCS-certified installers and equipment. This confirms that your solar units are properly installed and meet the MCS quality standard.
You will also need a smart meter to apply for the SEG, as it tracks your exported energy. Installation sequencing matters for some programmes. Certain grants require the PV system to be installed first, with the battery added as a top-up under the same scheme.
Lastly, remember to review and check all paperwork before signing the contracts of various grants. It’s better to understand everything in the fine print rather than having to clarify it at a later period.
Maximising Your Savings: Export vs Store
Both options can save you money, but the economics often favour storage.
Under the SEG, exporting typically earns around 5–15p per kWh. In contrast, using stored energy during the evening or peak-rate hours can offset electricity that would otherwise cost 25–30p per kWh. In many cases, that makes self-consumption the more valuable choice.
Even if your solar panels were funded through a grant, adding a battery can significantly boost your long-term savings by reducing the amount of electricity you need to buy from your supplier. To make the most of your system, consider using intelligent energy management systems like EcoFlow’s AI-powered energy management system (HEMS) and energy monitors, such as PowerInsight 2, to help you optimise when your battery charges and discharges.
Are Solar Grants and Storage Really ‘Free Solar Energy’?
Grants reduce the upfront cost of solar system purchases and installation, but electricity is not entirely free. There is no such thing as completely free solar energy. You still need to set up and maintain home systems to harness sunlight. Over time, electricity becomes significantly cheaper and cleaner when you rely on a renewable source like solar panels.
When using a solar system, incorporating a storage unit helps in maximising the “free” daytime energy your system has generated instead of selling it back to your providers. Storing energy will allow you to use it during the night or when the grid is at its peak hours.
Using battery storage is key to getting the most value from a grant-funded solar project. It reduces both initial costs and long-term electricity bills.
How To Combine Grants and Home Storage Smartly
Grants can ease the upfront cost of going solar, while adding a home battery storage helps you maximise long-term savings by storing surplus power for nighttime or peak-rate use. Together, they make solar more accessible and more financially beneficial for homeowners.
When exploring funding, check both national and local grant options, verify installer credentials, and estimate your system’s payback and overall household impact. For storage, the modular EcoFlow PowerOcean system integrates easily with existing solar setups.
Solar adoption continues to rise across the UK, supported by strong government incentives. If you’re ready to take the next step, request a consultation with EcoFlow to get expert advice on installation costs and upgrade options.
Can you get a government grant for solar panels or battery storage?
Yes. There are several government-backed solar power grants available in the UK, covering both solar panel installation and, in some cases, battery storage. Check the eligibility requirements of each programme before applying.
How much is the government giving for solar panels?
The amount that you can get from government grants can vary based on your income, the programme that you applied to, and whether you export energy to the grid. Check the respective grant policies before signing anything.
Do I still pay for electricity if I have solar panels in the UK?
Yes. Solar panels and grants reduce your bills, but do not eliminate them entirely. Adding home battery storage lets you use more of what your panels generate, which reduces how much you draw from the grid.
Are there any grants for solar batteries in the UK?
Yes. Several programmes cover battery storage alongside solar panels. ECO4 can include battery installation for eligible households. The Warm Homes plan and some local authority schemes also offer battery storage grants for qualifying applicants. Eligibility depends on your income, property type, and location, so check each scheme's criteria before applying.
What is the Warm Homes plan and does it cover solar?
The Warm Homes plan is a government scheme that helps low-income and fuel-poor households upgrade their homes with energy-saving measures, including solar panels and heat pumps. The England and Wales variants can provide up to £30,000 in funding. Eligibility is based on household income and property energy rating.
