MPAN Number on Meter Explained: How UK Homeowners Can Find Their Electricity Supply Details
Your MPAN (Meter Point Administration Number), also known as an S-Number or Electricity Supply Number, is a unique 21-digit identifier assigned to your property’s electricity supply point. The full supply number is typically shown as a 21-digit reference on your electricity bill, within your online energy account dashboard, or by contacting your local Distribution Network Operator (DNO).
Key Takeaways
Property Identifier: An MPAN identifies your home’s unique entry point to the electricity grid, remaining unchanged even if you replace your physical meter or switch suppliers.
Not Found on Physical Meters: Unlike meter serial numbers, MPAN details are generally not displayed on the physical electricity meter.
Essential for Switching & Upgrades: You will need your MPAN when switching energy tariffs, moving house, or setting up solar and battery installations like the EcoFlow OCEAN 2 Plus Single Phase system.
Distinct from MPRN: Gas connections use a separate identifier called an MPRN (Meter Point Reference Number), which is shorter and follows a different formatting structure.
Why Is an MPAN Number Important for UK Homes?
Tucked inside utility statements lies your MPAN—a vital string of figures that acts like a digital postal code for your electrical setup. Understanding why this number exists helps streamline routine property tasks and energy management.
Understanding the Purpose of an MPAN Number
Behind every light switch and kitchen appliance is an infrastructure managed by regional network operators. Your MPAN—short for Meter Point Administration Number—serves as the official reference used to identify your specific electricity supply connection. Created during the deregulation of the UK energy market, this standard numerical code allows energy retailers to route billing data, manage grid loads, and track consumption without confusing neighboring properties on the same street.
Common Situations Requiring an MPAN Number
Life events involving your property frequently bring this 21-digit number into focus:
Switching Energy Suppliers: When moving to a competitive tariff with providers like Octopus Energy or British Gas, retailers usually require the MPAN to help identify the correct electricity supply when transferring your account.
Moving into a New Home: Settling into a new property requires setting up a fresh account; providing the MPAN prevents cross-billing with previous occupants.
Grid Upgrades and Smart Meters: Requesting a smart meter installation or upgrading grid infrastructure requires your Distribution Network Operator (DNO) to pinpoint your connection point.
Registering EV or Solar Tariffs: Specialist eco-tariffs often require verified supply details before export payments or off-peak rates can be authorised. For homeowners preparing for solar and battery upgrades, understanding their electricity supply details is also an important step before choosing solutions such as EcoFlow Solar Battery.
Changes That Do Not Affect Your MPAN
Because your MPAN is linked to the physical land parcel and property connection rather than equipment, several common household changes will not alter it:
Replacing Your Meter: Upgrading from an old dual-rate unit to a smart meter changes the physical device’s serial number, but your MPAN remains identical.
Changing Energy Providers: Switching suppliers affects billing terms and account references, yet the underlying grid supply number remains tied to your home.
Changing Tenant or Owner Names: Updated account details modify who pays the bill without altering the registered supply identifier.
Where Can You Find Your MPAN Number?
Locating an MPAN can sometimes feel confusing because homeowners often assume it is stamped directly onto their physical meter box in the hallway or exterior cabinet. In reality, retrieving this detail relies primarily on administrative records.
Checking Electricity Bills and Online Accounts
The fastest route to your MPAN is reviewing a recent electricity statement. Your electricity supplier will usually include this information on your bill or online account.
Look for a distinct box containing a large ‘S’ followed by two rows of numbers:
The top row contains profile types and meter timing indicators, while the bottom row forms the core 13-digit identifier unique to your premises. If you have moved to paperless billing, logging into your supplier’s web portal or mobile app under “Account Details” or “Supply Info” will display this exact block.
Requesting MPAN Details From Your Supplier
When paper bills are misplaced and digital account access is unavailable, contacting your current electricity provider is the next logical step. Customer service agents can retrieve your supply identifier after verifying standard security questions.
Alternatively, if you have just bought a property and do not know who supplies the power, you can call your regional Distribution Network Operator (DNO). By quoting your full postcode and address, your local DNO may be able to help identify your MPAN after verifying your property details.
Common Mistakes When Looking For MPAN
Misunderstandings frequently delay administrative applications. To save time, keep these common missteps in mind:
Confusing the Meter Serial Number (MSN): Stamped directly on the glass or plastic casing of your meter alongside barcodes, the MSN identifies the physical box, not the supply connection.
Searching the Gas Meter: Gas meters display an MPRN (Meter Point Reference Number), which lacks the characteristic “S-grid” block format of an electricity MPAN.
Using the Customer Account Number: The reference number listed at the top of your monthly direct debit email belongs to your provider’s internal billing software, not the UK grid registry.
How Is MPAN Different From Other Energy Numbers?
Energy paperwork in the UK features various reference strings, making it easy to confuse one code with another. Distinguishing between these utility identifiers ensures smooth communication with technicians and energy advisors.
MPAN vs Meter Serial Numbers: The Key Differences
While both numbers relate to your electrical setup, their roles are completely distinct. The Meter Serial Number (MSN) is a combination of letters and numbers stamped onto the physical hardware by the manufacturer. If a technical fault occurs and engineers replace the physical meter box, you receive a brand-new MSN. Conversely, your MPAN generally remains linked to your home’s electricity supply point, regardless of how many times hardware gets replaced over the decades.
MPAN vs Gas Supply Numbers: The Key Differences
Homes equipped with dual-fuel supplies possess two separate supply references. The MPRN (Meter Point Reference Number) governs your natural gas line. Unlike the complex 21-digit MPAN block structure, an MPRN consists of 6 to 10 digits without an “S” logo. Gas identifiers are managed by Xoserve rather than regional electricity DNOs.
Comparing MPAN and Other Energy Reference Numbers
| Reference Type | Length / Format | Where to Find It | What It Identifies | Changes When... |
| MPAN | 21 digits (full supply number, including S prefix) | Electricity bills, online portal | Electrical connection point to grid | Usually unchanged (linked to property supply point) |
| Meter Serial Number (MSN) | Variable (alphanumeric) | Printed on physical meter front | The physical meter hardware | Physical meter is replaced |
| MPRN | 6 to 10 numerical digits | Gas bills, gas meter label | Natural gas connection line | Usually unchanged (linked to gas supply point) |
| Supplier Account No. | Varies by supplier | Bill header, bank statements | Your personal billing account | You switch providers |
How Is MPAN Relevant During Energy Upgrades?
Modern UK households are increasingly adopting clean technology to reduce reliance on the national grid and buffer against rising energy costs. When planning domestic energy upgrades, your MPAN shifts from a passive billing detail to a crucial prerequisite for installer assessments and regulatory approvals.
Why Installers Need MPAN Before Energy Upgrades
Before fitting solar panels, home batteries, or high-power EV charge points, certified installers must evaluate your home’s existing electrical infrastructure. Requesting your MPAN allows engineers to check your regional connection specifications, verify service cut-out fuse capacities, and submit mandatory notifications to your Distribution Network Operator (such as G98 or G99 grid applications).
For homeowners considering comprehensive solar and battery retrofits, modern residential setups illustrate how seamlessly grid connections integrate with self-generation technology.
Modular home storage solutions—such as the EcoFlow OCEAN 2 Plus Single Phase system—demonstrate how modern hardware can be integrated with common single-phase UK residential connections. Having your MPAN ready early helps installers assess whether your existing electricity connection is suitable for planned solar and battery storage upgrades, including systems with backup power features.
Preparing Your Home Details For Energy Upgrades
Streamlining an energy installation requires organizing key property details ahead of the site survey. Having these items accessible prevents delays during the planning phase:
Current MPAN Details: Found on your latest statement to assist with DNO grid permission filings. For some solar projects, homeowners may also need an MCS certificate or certification from an MCS-approved installer, especially when applying for certain export schemes.
Consumer Unit (Fuse Box) Photos: Showing available breaker slots and main switch ratings.
Recent Annual Consumption (kWh): Helping system designers size solar arrays and battery capacities accurately.
MPRN Details: Helpful if replacing gas heating with heat pumps or hybrid systems. As energy upgrades become more integrated, homeowners can also consider a Home Energy Ecosystem approach that connects solar generation, battery storage, and smart energy management to support more efficient household energy use.
.png)
Managing Energy Use After Home Upgrades
Completing a solar or battery upgrade often leads homeowners to pay more attention to daily energy usage and system performance. Homeowners naturally become keen to track daily solar generation, battery storage reserves, and net grid imports to maximize financial returns.
To make complex energy flows easy to interpret, smart management interfaces play a vital role. Touchscreen energy displays like the EcoFlow PowerInsight 2 offer a practical example of centralized home energy visualization. By displaying real-time power generation, storage levels, and household consumption on a clear panel, systems like this help families monitor their energy habits, optimise off-peak usage, and better understand energy consumption patterns to make informed daily energy decisions.
Your MPAN is a long-term reference linked to your property’s electricity supply connection. Whether you are switching energy suppliers to secure better rates, moving into a new home, or taking steps toward self-sufficiency with solar panels and home batteries, knowing where to find your MPAN helps you better manage energy-related administration and prepare for future upgrades. By keeping this identifier alongside modern energy management tools, you can navigate grid-related processes more efficiently.
Disclaimer: Energy upgrade requirements, installation standards, and grid connection processes may vary depending on your location, property details, and local Distribution Network Operator (DNO) requirements. Always confirm technical requirements with a qualified installer or relevant energy professionals before making changes to your home energy system.
How do I find out my MPAN number?
You can find your MPAN number printed directly on a paper electricity bill or within your energy supplier’s online account dashboard, usually displayed inside a distinct box marked with a large ‘S’.
Where is the MPRN number on my smart meter?
The MPRN is not shown on your smart meter’s digital display. While it can sometimes be found printed on a label or sticker attached to the physical gas meter casing, the quickest way to verify it is by checking your gas statement or logging into your energy supplier’s online portal.
Does Every UK Home Have An MPAN?
Yes, Every electricity supply point connected to the UK distribution network has an MPAN number assigned to its connection point.
Can I Find My MPAN Without A Bill?
Yes, you can find your MPAN without a bill by calling your local Distribution Network Operator (DNO) and providing your postcode and house address.
Is the MPAN number confidential?
No, an MPAN number is not considered sensitive confidential data like bank details, though it should be kept on record for your own property administration and energy switching needs.
