Choose your country or region
Interested in a 10 Kilowatt Solar System? What You Should Know
If you want your home to be more environmentally friendly or you’re simply looking for lower energy bills, a 10-kilowatt solar system is the hardware of choice. Able to provide a continuous supply of free electricity for your home, a 10kW setup like the EcoFlow PowerOcean Home Battery System can meet the needs of large families or even small businesses.
That's something we'll be delving into now as we explore the benefits of a 10000 watt solar system and highlight some other interesting aspects of the hardware. So why not stick around and expand your knowledge of this increasingly popular technology?
The Benefits of Investing in a 10 Kilowatt Solar System
Money is tight for many people these days, so a big investment like this one needs to be researched fully. In this section, we look at the range of advantages that come with putting your money into a 10 kilowatt solar system. Spoiler Alert: It can be a real game-changer!
  • Big Energy Bill Savings: People across the UK have seen their energy bills skyrocket in recent years, and a 10000 watt solar system represents the perfect antidote. Allowing you to majorly reduce your electricity bills both in the short and long-term, it's an investment that keeps on repaying you year after year.
  • A Smaller Carbon Footprint: When you opt for a renewable energy system for your property, you greatly reduce its carbon footprint and impact on the environment. More and more people understand the crucial nature of climate change, and technology like this is key to turning the tide in our favour.
  • Low Maintenance: The peace of mind that comes with a 10 kilowatt solar system also requires very little in the way of maintenance. Just a regular clean and a periodic check from a qualified technician is all that's needed for continuous, reliable power.
  • Help With Up-Front Costs: While the initial cost involved with a 10 kw solar system can be pretty hefty, there is help available in the form of Government incentives like the Green Homes Grant to assist you in meeting the 10 kilowatt solar system cost. A such, it can end up being much more affordable than you think!
  • Energy Independence & Security: Hardware like this also gives you energy independence in that you're not subject to the whims of the power companies. Also, with a 10kw battery system in place, you can ensure your home still has access to electricity in the event of an emergency outage.
In essence, when you invest in a 10 kilowatt solar system, you get to enjoy a wide range of associated benefits, not just lower energy bills. At the same time as protecting yourself against power company price hikes, you also contribute to a brighter, greener future for everyone.
How Much Electricity Does a 10kW Solar System Produce?
Typically speaking a 10000 watt solar system installed in a UK home will produce around 9,000-12,000 kWh each year. The variation is caused by a number of factors, such as what type of shading is in the area, and which way the solar panels are facing.
So, what does that mean in terms of what it will be able to power? This output is sufficient to meet the average UK household’s electricity requirements for the year, meaning all of your lighting, appliances and heating. Naturally, a 10 kilowatt solar system will generate more power during the summer and less in winter.
The good news is that if your power usage is at the lower end of the spectrum, any excess electricity that’s produced can be exported back to the grid - meaning any bills you do get are going to be lowered - or stored in a 10kw battery for later consumption.
How to Get the Most From Your 10kW System
As we alluded to a moment ago, there are a number of factors at play that make your 10 kilowatt solar system more or less efficient. This is something that your installation technician will take care of for you, but it still pays to know what changes things, so here’s the lowdown.
Optimal Placement
An installation technician will usually install the solar panels for your 10kw system on a south-facing roof with as little shading as possible, as where your panels face will have a bearing on output. Another factor influencing efficiency is the tilt and angle of the panels, that affects the level of solar absorption that occurs. In the UK, optimal angles range between 30-45 degrees.
Regular Maintenance
If you want your 10 kilowatt solar system to operate at its very best level, it’s important to take care of maintaining the hardware. It doesn’t take much effort, as all that’s required is a to keep the panels clean and free from debris and shading. A regular once-over will also allows you stop damage (which can happen during storms) or malfunctions early.
Whether You Use Energy-Efficient Appliances
It’s not just about the solar hardware you use, as the appliances that are powered by it also play a big part in the efficiency of your home. Whether talking about your fridge-freezer, microwave or washing machine, be sure to opt for appliances that display an A+++ rating. The full rating system in the UK ranges from G, at the bottom, right the way up to A+++.
Using Energy Monitoring Systems
Something else that will influence the performance you get from your 10 kilowatt solar system is whether you have an energy monitoring system included. Devices like the EcoFlow Power Insight give you all kinds of data relating to consumption patterns, real-time energy production, total energy production and cost analysis. It gives you everything you need to hit that sweet spot and optimise your system.
How Many Panels Are Needed in a 10kW Solar System?
In order to have a 10 kilowatt solar system installed in your home, you either need sufficient roof or garden space for the requisite panels. You'll need around 40 solar panels, so you'll need a standard-sized roof to accommodate them. The average size in the UK is 65-70 sq metres, and this many panels equates to roughly 64 sq metres.
That said if you don't quite have enough space for this many panels on your property’s roof, a 10 kW solar system might still be possible with careful planning and customisation by a professional installer.
Talk to the EcoFlow Experts About a 10 Kilowatt Solar System For Your Home
The advantages of a 10 kw solar system for your home are clear, and while there is an upfront cost involved, it pales in comparison to the long-term savings that are on offer. Of course, there are other aspects that need to be considered, and you need to be sure that this type of system is right for your needs. That’s where EcoFlow’s experts come in.
If you’d like to learn more about adding this kind of functionality to your property or you’re interested in getting a tailored quote, the best thing to do is visit our website Homebattery.ecoflow.com/uk. Alternatively, to speak about your requirements with our team directly, go to our homepage and click 'Order Now' and we’ll get back to you as soon as we possibly can.
